Hi Targa Florio,
Which cams did you purchase? You know, you probably should have spoke to your Alfa Guru before buying them, yes?
What kind of driving do you do and when (in the RPM range) would you want your power to come in? Working with less than 2L is a bit of a challenge you know. The factory has probably already done what you're looking for!
Without displacement, it's virtually impossible to get any more ummf, down low without power adders (NOS/SC/Turbo). Cam's will get you a tad more power, but up top. Combine the perf cams with more compression (10.5:1 or better) and you can attain substantial more (percentage-wise), but down low will suffer a lot.
I don't know the 1750, but maybe you can have the head decked for a lot less than forged pistons, and that should buy you a teeny bit of compression and leverage the benefit of the cams a bit more. I'd make sure my fuel system is running tip-top...
