I would suggest calling HASTINGS to Dawn the Tech engineer 269-945-2491 ext 1359. she will need ring thickness,, width, and type.
Since ring gap increases .003 with every .001 bore increase I suggest getting rings to fit & they will be less expensive. The 3 piece oil rings will not need to be gapped but if the others do she can tell you the spec.
You will want there "3 piece oil rings" and she will probably suggest running the same design top 2 rings with the 2nd ring upside down as it is a scraper. But tell her your use and they have many designs and sizes. You might visit their website for a look first.
Hastings
