04-22-2008, 03:29 PM
Hey, is a Fiat twin cam engine a better design for racing than the Nord? It is more of a pent roof, if I'm not mistaken. Anyone know a bit about the Fiat engines?
I rode (actually I drove it too) in an early 70's spider with a Guy Croft head and dual side drafts...it was pretty fast.
1984 GTV-6 - 80K miles
04-22-2008, 07:25 PM
ive actually got a fiat and yes, the motors are a better design. The lampredi engine was one of the most influential designs ever, but remember that the Fiat engine came along almost 15 years after the Alfa one. Everything on the Fiat Twin Cam has been thoughtfully designed; the head is pretty good, flows well, good chamber design, and the bottom end is solid as (forged parts from factory depending on engine). And then theres the integrale 16V...
04-22-2008, 07:35 PM
Originally Posted by genericwood
Raff, our Nord engines are relatively long stroke. The piston speeds can get really ridiculous at 8000+ rpm. Most race engines are running aftermarket rods which can handle it, but both rod and main bearings get very short-lived if you are going to go much higher. Of course, this assumes that you are running lightened valve gear and really good springs.
You are correct about the combustion chamber shape being poor. When you start getting the compression you need to make big power, the shape gets even worse. But the other big limitation is the port angles. It's really tough to get the mixture to turn the corner to fully utilize the valve size.
Erik
Thats the other thing I've been told, that the 2 litre has too large a stroke to rev hard enough to make more power with the standard head.
04-22-2008, 08:48 PM
Richard Jemison
Bull Sh!t
Same Stroke as a 1750??
Problem is components & doing things the "Old Way"
Yes, increasing the dome of the piston ruins the combustion chamber shape, FU flame propagation & screws valve flow, and puts too much weight in the top of the piston... But just because Autodelta did it due to design limitations in the `60 (and they were not creative to the extent of Alfa $$$ spent), does not mean it needs to be repeated in perpituity!
Alfa motors are plentiful. These are not collectables! Cut the block & front cover. Cut the heads till there`s only enough aluminum to hide the seats (berrillium). Use "shaped" low center dome pistons with as little valve cuts as possible to clear light small stem stainless or better yet, Titanium valves opened by current cam design. Port the head high & open to & around the valve guide area. Raise the intake manifold...Etc. etc.
In reality a 2 liter with stock modified components (modified block, pistons, head, valves, rods, and crank) can make 220 HP under 7500 RPM.
And live
8000 RPM is for those that have $$ to piss away!
Alfa Racers are semingly stuck in 1967 continuously!
So, newer head designs are better... These work fine if you work them a bit...
By the way what does an "expert" prepred race motor cost outright now? What "Real Raceing time" is it expected to run before rebuilding?
Richard Jemison
RJR Racing
http://scuderiagiallo.com
04-29-2008, 10:14 AM
Originally Posted by JoeCab
Yes, that is about the limit. Here's a dyno graph of a pretty serious 2 liter.
Joe, did you have a set of Mike Sperry's headers on the engine when you dyno'd it?
bill
04-29-2008, 06:50 PM
... and another $.02 worth.
Richard and Eric have the background knowledge here. I spend lots of time restoring the odd collectable parts for some of the old NORD race engines. The design WAS state of the art in 1955. It is now 2008, and quite a few new ideas have been generated in the past 53 years. I have been driving my '65 Ausca GTA engine on the street now for years. In May of '74, after a rebuild, it had 167 Hp @ 7500 on Ron Neals dyno. Between 7000 & 7500 it lost it's 2nd pound of oil pressure. Torque had dropped from 118 @ 6500 to 112 at 7500. It was done. Sure, with todays titanium valves and my new cams from Richard, I can wind it higher, but there is nothing to gain.
With a 2L, as Richard suggests, you have added more piston weight, and a even longer stroke. That will not help it build power at 8,000 RPM + with the existing head design. Even with the best of current internal components, the 2L, 50+ year old design has it's limitations. Failure to recognize this can be just another expensive mistake.
Re - read Eric's post. It's FACT based on experience.
 Gordon Raymond
Illinois SNO Chapter DIRECTOR
Reason: a few typo's
04-29-2008, 10:54 PM
I have to say 220hp under 7500 RPM is very appealing. I also have to raise my hand as one of the folks stuck in 1967, however I am trainable.
B
05-01-2008, 01:17 PM
My stock 2.0 TS (AR67202, 90mm stroke, 84mm bore) got dynoed at 164.5 Bhp at 6300 RPM and 213.8 Nm at 5200 Rpm a few years ago. I fully recognise this engine has a better head design compared to the twincam though, but heard some rediculous claims that it's "very expensive to get more than 175 bhp out of an 8v twin spark engine".
I'm now in nthe process of rebuilding it, and aiming well above 200 Bhp without going to extreme RPMs in the process... I'm firmly under the impression these engies got deliberately limited in power output by the factory, by undersizing the injection system (motronic M1.7)
I still have a lot of questions for you guys though, seems like the best place for information about these older engines
05-07-2008, 04:44 PM
Alfar7
BUT... If you cut the block and shave the head... aren't you also redusing the displacement... say from 2 liter to 1950... or less? Not sure how much cutting you are doing. WIll the stroke be shortened enough so that the engine will be able to spin fast enough to compensate for the smaller displacement??? I know there are other variables but... will that be enough?
Sprintn
05-07-2008, 06:07 PM
Originally Posted by Sprintn
Alfar7
Sprintn
No engine displacement is a function of bore and stroke and they would remain the same. Only the compression ratio would potentially be altered by cutting the block and shaving the head.
Also does anybody know what Cosworth do to old Jaguar straight sixes to get them to produce like 50hp more than they used to back in the 60's?. These engines are very similar in head design/porting, combustion chamber and long strokers like the Nord engine. Lightweight E-Type Jags now blow Ferrari GTO's away which was not the case in their day ... thanks to modern engineering fncking classic racing .
05-07-2008, 06:20 PM
Pete, one thing they are doing is turning the motors at much higher RPM's. The mod was actually developed here in the states when a Jaguar shop fitted ---I think---a 427 Corvette crankshaft damper on the Jaguar motor and suddenly discovered a reliable 7000 +/- RPM. Jags then started going much faster.
'70, 1750GTV, 2nd series
05-07-2008, 06:23 PM
Yes... i agree... but in the context the reply was written... following on something about a nord engine not being able to turn quickly due to its long stroke... and him saying to cut the blocks... it almost sounded as if he was suggesting to cut the block enough to actually HAVE to shorten the stroke.  Crazy but I guess it would be possible.?.? But yes... I also agree that shaving the head would be done to increase the compression.
