#61 (permalink)
Old 03-27-2008, 04:09 PM
Gabor K. Gabor K. is offline
Interesting, as I see, however why not go race style alltogether and close the bottom of the frame and get dry sump with the bottom bearing carriers. You will than have a lower engine center, the increased rigidity, but must have an external oil pump for each oil cavity.
  #62 (permalink)
Old 03-27-2008, 06:48 PM
slyalfa slyalfa is offline
That is what I was thinking. but also add a triangle too so the side of the cap is locked in.
And mabee weld the caps to it...
The bolts of the caps would need to be longer or the caps shaved down.
even if it is just a bolt on it might make sence to mill the caps down where it mates to the bedplate as the bed plate will add back the thickness. Then the fit will be dead on. Right now the caps are cast on that end and the fit would be vey bad. and some caps 164s have a flate spot to mount the oil pick up on one cap.
if the caps are milled it might be good to leave a rased part in the center to help lock the cap.
a round peg that fits in a drilled hole in the bedplate.
1987 black Milano Verde
1972 White spider 2000 Veloce
  #63 (permalink)
Old 03-28-2008, 02:28 AM
FMG_V6_btb's Avatar
FMG_V6_btb FMG_V6_btb is offline
If you decide to use an integral bottom frame with the bearing caps included, you will need to realign (mechanize) the entire bearings line, and that could be critical if you want to maintain the original bearings and crank.
Closing the bottom like race engines will add stiffness, but will make the part more difficult to manufacture, and the necessity of three external scavenge pumps...
If you look to the design, the side of the bearing caps are locked, so the triangle shape is not needed, also note that it is necessary to have some "windows" between pair of cylinders to allow the internal air in the crankcase to circulate (pumping effect of the lower part of the pistons), so the triangular space is needed.
I don’t recommend welding or cutting the original bearing caps, which could deform or impair those critical parts.
Longer bolts are needed, and round pegs could be inserted in the main bearing bolt holes to add some more stiffness.
Paco.
- '93 164 QV [COLOR="Red"]Rosso[/COLOR]
- '02 156 2.5 [COLOR="Red"]Rosso[/COLOR]
- '08 FMG 3.8 [COLOR="Red"]Project[/COLOR]
  #64 (permalink)
Old 03-28-2008, 04:33 PM
hmm welding I could see, but I would not think milling would deform them. the part to mill is quit far from the crank and I would not think taking some off would affect it. and if they were milled flate the bedplate could lock on the them, and the milling of the bedplate would be easy as a standard pocket mill would be used insted of a very slow $$$ many many pass to make up the curved part.
  #65 (permalink)
Old 04-18-2008, 06:20 AM
daz's Avatar
daz daz is offline
Paco
this thread is extremley interesting and I hope you keep us all informed as to your progress and finished product.
Im no engineer just a do it yourself enthusiast and although this is beyond me its still a worthwhile thread, its a fresh approach and hasnt been discussed a thousand times before
Keep it going
  #66 (permalink)
Old 04-18-2008, 01:28 PM
FMG_V6_btb's Avatar
Sorry guys, I'm really very busy but don't forget the thread, I will continue with it ASAP.
  #67 (permalink)
Old 04-21-2008, 09:20 AM
SovraPressione SovraPressione is offline
Paco this thread is extremely interesting please continue posting, to completion we hope.
We Alfa enthusiasts need these as there are not much "open" concept on this matter in comparison to the Hondas, Nissans , Mitsus engines etc out there where they seem to have everything developed by zillions of their enthusiasts for the benefit of the end users.
Whether it will be on an Alfa chassis that is a different matter,the Alfa V6 engine is the soul of the marque in the first place.
  #68 (permalink)
Old 04-22-2008, 02:14 AM
Kevin Johnson Kevin Johnson is offline
Originally Posted by FMG_V6_btb View Post
Maybe some of you would be interested in my project...
I have planned to modify deeply a 3.0 V6 24 Valve engine, to obtain a reliable 450-475 HP engine. The engine will be twin turbo, and the cylinder capacity maximized to be around 3.8 litres.
Since I have seen in the net many V6 engines with crank-rod failures (as mine), to build a reliable engine, means to solved this problem, and the better way is to design a new crankshaft with increased stroke and rod journal diameter and width (lower bearing surface pressure):
I enjoy reading the thread and discussion of engine design. However, the first plan of action seems to be to determine why the crank/rod failures happen. I have never owned an Alfa but just spent about four hours contemplating your posts and then reading various threads on rod bearing failures.
A common mode seems to be the slipping of the timing belt thereby causing interference and bearing damage.
All the mods proposed thus far do not address this common problem. I think there is a high risk of changing too many things in the engine and departing from good scientific/experimental method.
I think if you contacted a number of shops heavily involved in the rebuilding of V6 Alfa engines they could tell you why the damage occurred in various instances. That is a big task in and of itself, of course. You are proposing to share your results so this may foster openness with the shops involved.
Perhaps one of your students could be recruited to perform this task as a good real world excursion into failure analysis.
Also, there are many professional engine designers prowling on the Engineering Tips forums to bounce ideas off of.
  #69 (permalink)
Old 04-22-2008, 04:44 AM
FMG_V6_btb's Avatar
Hi Kevin, I have been analyzing the possibility of design and manufacture a new crank with increased stroke, there is no problem in doing that, the problem arises when try to assemble it to the rest of the engine.
Design a new crank only worth if the stroke is substantially increased, as this engine can be easily fitted with a 78 mm stroke GTA crank, a new design must have as least 82 mm stroke, and this produces the following 2 problems:
1 Due to the relatively short rod, the resulted maximum rod angles are the following:
72.6 mm stroke = 16.7 deg.
78 mm stroke = 17.3 deg.
82 mm stroke = 18.2 deg.
16 deg. is near of the “normal” limit (lateral forces between piston and liner), so this engine with a 78 mm stroke crank is a little saturated, and much more with an 82 mm stroke crank.
2 In order to (almost) maintain the crank rigidity, the connecting rod journal diameter must be increased, and this is a problem because this engine has big diameter journals and increasing it would produce a very wide rod big end which together with the increased stroke would made the rod touch inside the crankcase, specially in the area near the liner end of the opposite cylinder.
So, I think is justified NOT design a new crank, and use a 78 mm GTA one instead.
About crank failure, I think the reinforcement of the main caps and engine structure with a girdle will allow the crank to work in better conditions, and if the oil system is revised and improved (flow capacity and temperature control), I hope the crank will last a little more (taking control of the maximum in cylinder pressure, knock, etc.).
Paco
  #70 (permalink)
Old 04-22-2008, 08:15 AM
... About crank failure, I think the reinforcement of the main caps and engine structure with a girdle will allow the crank to work in better conditions, and if the oil system is revised and improved (flow capacity and temperature control), I hope the crank will last a little more (taking control of the maximum in cylinder pressure, knock, etc.).
Paco
Have there been reports of fretting on the main cap registers or parting lines (edit: surfaces) in high output engines? This would be a sign that the caps need to be further stabilized. It is clear from the existing design that Alfa engineers were cognizant of the issues.
It would be informative to know if the center two mains were always so much taller than the end two caps. It is of great value to study the evolution of an engine design over several decades. This is information that an established rebuilder would likely know and might be willing to share. With newer engines this design lifespan is greatly reduced.
It might be possible to obtain this information from vintage factory service manuals. It is probably very important that the manuals be printed in the era of various iterations of the design. I say this because I have compared manuals for Renault engines spanning decades and much of the earlier information is deleted over time -- this is for manuals with even the same numeric title/designation and purporting to cover the same years.
If this issue can be eliminated or confirmed then the effort can be still more focused.
  #71 (permalink)
Old 05-13-2008, 10:25 AM
alfaspence's Avatar
alfaspence alfaspence is offline
Not sure if anyone had mentioned this before, but whats wrong with polishing and shot peening the rods and crank? This method of strengthening is age old and produces good results....
Detonation should be addressed and cured, not masked up with stronger components...
Why 3.8? i know theres no substitute for cubes, but really, if you design the intakes and exhausts correctly, cam profile selection also, theres no reason why you shouldn't be able to see near 450 bhp from a twin turbo 3 ltr 24v running approx 8-12 pounds of boost (pump gas)
If i had the funding, i would be more than willing to put this theory into practice
Before anyone attacks, i have been in (and out) of engines for a good 14 years now, and had very good results arising from work that i have done...
(but i work from old fashion methods, not new computer generated ones, allthough iam not saying that new technology is all bad tho)
Spence
75 3.0 24v
  #72 (permalink)
Old 05-15-2008, 04:25 AM
Those are good techniques. Two questions pop into my head -- neither of which may apply to the V6 under discussion: 1) If the crank has already been hardened in some way is shot peening safe or simply redundant?; 2) Does or did the engine ever use powdered metal rods and is shot peening safe or recommended?
Perhaps in 1) the grinding/polishing removes the hardened layer. Anyway, easier to ask about this now than to contemplate a collection of unusual steel paperweights.
  #73 (permalink)
Old 05-15-2008, 08:04 AM
Paco: You could just buy a 450Hp crank instead of trying to work out something yourself, unless you can make something for free? Have you checked?
  #74 (permalink)
Old 05-15-2008, 09:10 AM
alfaspence's Avatar
Originally Posted by Gabor K. View Post
Something like this for the road? This one is without turbo and around 450Hp.
Just reflecting back quickly, that widebody mid engined 156 is forsale!
"This central-seater silhouette racer has carbon fibre Alfa Romeo 156 bodywork and is powered by an Alfa Romeo 3 litre V6 24-valve engine with 440 BHP."
thats an extact from the actual advert, thats right 3ltr N/A with 440 BHP!!
Twin turbo 3ltr? Goes to show the only advantage of going 3.7/3.8 is extra torque
Spence
75 3.0 24v
  #75 (permalink)
Old 05-15-2008, 09:16 AM
alfaspence's Avatar
interesting questions indeed! To be honest, i don't know the "makeup" of the original parts, so this is a question that may need addressing...
With all these 400+ hp 24v engines accross the world... more than one company is building / manufacturing parts for them... or are these made from unobtainium? or closely guarded secrets?
In case nobody has guessed by now iam very intregued by this project now
Spence
75 3.0 24v
