Go Back   Alfa Romeo Bulletin Board & Forums > Alfa Romeo Technical Forums > Engine Rebuilding
  #46 (permalink)
Old 02-29-2008, 05:14 AM
danyl's Avatar
danyl danyl is offline
Murray,
Another question, What do those reinforced motor-mounts really do for you?
Wouldn't they transmit more vibration?
Danyl
Danyl
1987 Spider Veloce, first and only owner...
  #47 (permalink)
Old 02-29-2008, 05:34 AM
oldschooleuros's Avatar
oldschooleuros oldschooleuros is offline
I do not have experience with them on Alfas, but have had them on other cars. Had poly mounts, and STRAIT SOLID mounts. The strait solids were a little worse, but bearable. The poly werent as bad, but were noticable. Just one of the "compromises" of adding power.
[COLOR="Green"]When cornering hard.... It's not the tires screaming...[/COLOR] [COLOR="Red"]It's the road begging for mercy. [/COLOR]
[COLOR="Red"]1985 Maserati[/COLOR][COLOR="Green"] Biturbo, 5spd. A work in progress. [/COLOR]
  #48 (permalink)
Old 02-29-2008, 06:22 AM
msiert's Avatar
msiert msiert is offline
Darkside Member
Originally Posted by danyl View Post
Thanks Murray,
Did you have the pressure plate/clutch balanced with the crank as well, or just the flywheel?
How do you think the aluminum flywheel would compare to just having mine lightened and adding the aluminum pressure plate?
Danyl
You know, I'm really not sure if clutch/pressure plate were balanced? The aluminum flywheel would be lighter then what your proposing but you would still feel a nice difference over the stock flywheel.
Becareful not to take too much weight off of it.
Murray,
Danyl
I got the mounts, flywheel and Tilton clutch at the link below.
Parts
I can't tell any difference in feel between those and the stock mounts but I shouldn't have to replace them as often.
I don't know if it's the extra HP of the stiffer mounts but I have had to tighten the loose nuts (with lock washers) that fasten the mount to the engine on two different occasions.
The link below shows the Tilton 7.25 Pressure Plate and Sprung Disc Pkg I got..........claims a 20 lb loss of ROTATING mass.
Performance Clutch and FlyWheel Parts
Murray
1991 Black Spider
The "Black Spider" project
Street Video
Track Video
  #49 (permalink)
Old 02-29-2008, 06:48 AM
Subtle Subtle is offline
Director BC Chapter SNO
Most threads on this recommend the aluminum flywheel.
My 2 L has one.
1962 Giulietta Spider: Graphite Grey/red; "Tuned" 2L.
1993 Subaru Legacy Turbo Wagon(200 whp).
  #50 (permalink)
Old 02-29-2008, 09:03 AM
Zunige's Avatar
Zunige Zunige is offline
In the Spider's Nest
I think you have two good choices for motor mounts. Those who use the reinforced Spruell mounts seem to be very happy with them. I went with the polyurethane motor mounts. They are only available from Don Ereminas (1-800-253-2468).
Best regards,
Enrique
Spider 74, 84 & 87
164 93L & 95Q
Milano 88 Verde
  #51 (permalink)
Old 02-29-2008, 10:02 AM
Alfar7's Avatar
Alfar7 Alfar7 is offline
Richard Jemison
Lightening things
For a street car an aluminum flywheel is a bit of overkill. The properly lightened stock unit can safely loose 5 pounds and all of it around the outer area where loss of weight affects centrifugal inertia the most.
The most productive change in the clutch assembly is going to a light alum. center no springs, clutch disk (see my website). the lack of wafer springs in the lining area releases cleanly and reduces wear on the syncros because residual drag is absent(that caused by the lining expanding on stock springs)and the light disk reduces the force that the syncros have to speed up or slow down with EVERY shift.
As for lightened gears it is OK if you are talking racing applications. But so little is lost in weight it is hardly worth the $$ except for the concept and personal satisfaction(and bragging rights). I`ve done them for years, but the real gain is from the replaced syncros & sliders and repaired or replaced shift forks. If you have to do it stick to the large gears, and for goodness sake don`t cut down the layshaft as pictured in Msiert`s pic below. All that cutting only reduced a few oz. of weight, at a point of no reduction on centrifugal force, and significantly reduced the shafts regidity, as the surface hardening is only about .040 deep. Yes the shaft can handle twist forces ok, but pop the clutch out in 2nd gear (as in serious downshifting) and suddenly your layshaft is a bit eccentric. Don`t bother to ask how I know..............
Loosing the heavy stock disk results in the best shift improvement.
By the way, nothing is similar or interchangable between a Alfa transmission and transaxle other than syncronizer pieces (from late 115 to 116/119).
Pic is of alum centered disk that can be used in 105/115 and with center spline change in Alfetta/Milano. The 4 puc is only for racing where higher torque clamp force is wanted (generally not needed in 4 cyl cars0
Other pics of lightened parts ( ring gear) and internals of my GTA box while getting syncros & dog teeth assembly replacements.
Richard Jemison
RJR Racing
http://scuderiagiallo.com
