Old 02-25-2008, 02:31 PM
FMG_V6_btb's Avatar
FMG_V6_btb FMG_V6_btb is offline
Help, V6 firing order
Please, I need to know the firing order of the Alfa V6 engines (I suppose is the same for all the V6 versions).
Thanks.
- '93 164 QV [COLOR="Red"]Rosso[/COLOR]
- '02 156 2.5 [COLOR="Red"]Rosso[/COLOR]
- '08 FMG 3.8 [COLOR="Red"]Project[/COLOR]
Old 02-26-2008, 04:35 AM
kredden's Avatar
kredden kredden is offline
Milano is 1-4-2-5-3-6.
Kevin
86 Spider Veloce
87 Verde
Milano registry custodian(www.alfamilano.com)
Old 02-26-2008, 07:10 AM
FMG_V6_btb's Avatar
Thanks Kevin!!
I thougt it was 1-4-3-6-2-5, because this picture, and assuming this is the correct numbering:
1 2 3
0--------|
4 5 6
Thanks again.
Old 02-26-2008, 10:00 AM
giuliettaevo giuliettaevo is offline
You found a new crank i see? than i won't have to take my engine apart.
Old 02-26-2008, 10:43 AM
FMG_V6_btb's Avatar
No, this is not my crank, it is just a picture from the net, and as you can see, seems like the first crank web is damaged.
My engine is still assembled, I haven't enough space to disassemble it at the moment, and first I prefer to have the new crank ready.
If I would have the crank, it would be easy to obtain the firing order from the crank web positions, so I continue needing the crank... maybe you can go to your garage and check if there is one available...
Old 02-26-2008, 12:36 PM
I've send you a PM about the crank a week ago...
In case you didn't get that i'll send it again.
Greetings Remco.
