04-27-2007, 11:22 AM
Originally Posted by Slapbass
I can pull a Porsche 914 engine in less than 20... But then again, who couldn't. You just have to remove some bolts and let it hit the ground.
Engine removal on an Enzo is even faster. Just ask Dietrich.
04-27-2007, 06:45 PM
Originally Posted by velocedoc
I have pulled just the engine in under an hour. (air tools really help) A whole engine with trans runs another hour because of the center console, drive shaft etc. Putting it back in is another story, as it takes lots of preparation to clean things up.
I'm with Chris - I pull the engine and leave the transmission. My best time, in my younger days, with a mid 70's Spider was around 90 minutes.
I pulled an engine/transmission from a '78 Spider I was parting out a few years ago in a couple of hours, but I have much better tools/shop now...
bs
04-28-2007, 10:06 PM
What is your trick for lining up the transmission? Are there any other issues?
I just installed the 1750 in the GTV Friday and found it to be much more of a pain than I expected. This was my first time installing so I expected it to take a while and it did. I wasn't too concerned about scratching the engine bay because this one wasn't painted and but when I put this 1750 into it's permanent home ('69 spider) it will be painted and I will be plenty paranoid. Osso and Papajam did it with Osso's muesum piece in a recent thread but I'm not in their league.
- Rich D.
04-29-2007, 08:07 PM
Christopher Boles
A tip, move the mounting bracket forward one set of studs so you can get a steeper angle on the engine/transmission. Then I would put some heavy tape over the top of the transmission gear selector so it doesn't scratch the firewall. Also put a heavy blanket/bathmat/cardboard on the front of the car so that when the pan drops into the engine bay you won't scratch the front. These should make life easier.
05-01-2007, 12:19 AM
I can do it in about an hour. Pull tranny then engine. The easiest way! The shifter bolt can be removed from the bottom, this cuts a lot of time.
05-01-2007, 12:40 AM
When I used to do this sort of stuff for a living I had a couple of tricks to get the time and effort down to a minimum:
One was: if I was doing a full engine rebuild on a 105 (and not touching the tranny), I first would pull the head/carbs and exhaust manifolds off, and then take out the bottom end. Installation was a reverse order: final assembly of the head/block in the car.
The advantage was the ease at getting at all the bolts down low (starter, bell housing and engine mounts etc) and under the carbs. Of course you don't get to see the lovely clean finished engine on a stand, but then you probably save an hour on the whole job.
05-04-2007, 10:20 PM
Pulled the 1750 out of the GTV Thursday. This was a temporary arrangement to allow me to break in this engine while I replaced the clutch on the 2L and cleaned the block. This time it took just a bit over 2 hours with two of us. A personal best!
My preference now is to pull the engine/trans/driveshft as a unit. I am also leaving the exhaust manifolds on the engine and disconnecting at the downpipes. I have found a 36" extension from under the car will reach all the downpipe bolts. I am using anti-seeze on the bolts so I'm not fighting rust in another year.
Jeff and the rebuilt 1750 coming out.
Installed the 2L Friday. I'm still not too quick (too many interuptions). I think the major difference is that when I started pulling the engine I had all my tools organized. The next day they were all over the place and I'm sure I spent more time hunting for stuff than working on the car.
I'm getting better anyway...
- Rich D.
I like Alfas
01-10-2008, 01:19 PM
A new personal best of 63mins for pulling a motor. That is for two guys pulling a clean carborated 2L out of a Spider. Getting to the lower motor mount nuts is so much easier on a carb'd 2L - they are all accessable from the top.
- Rich D.
I like Alfas
01-10-2008, 01:34 PM
ReAlfisted 3/06
Once we got this one going, buddy of mine & I were going, I'd say 5mph  .
1973 GTV - bought 3/06 (quiet, he's asleep for the winter)
1969 GTV, #AR1530021 - sold 10/72
02-23-2008, 09:49 PM
compratore di alfa
Never pulled an engine in my life, it took me about 7 hours by myself to pull an engine/transmission from a 164.
02-24-2008, 12:04 AM
BMW 650i engine in 2.7 hours.
Sniady
'how the devil do they do that with a live rear axle?'
02-24-2008, 12:18 AM
Admin
Took me and my assistant a few days to get everything disconnected. The actual pull took only a hour or two.
02-24-2008, 03:22 AM
Slacker
Hmmm, looks like it had a bit of a leak.
02-24-2008, 09:36 AM
I cannot really say for an Alfa, but for a Plymouth Laser, 3 hours
Dodge Omni- 4 hours (auto)
02-24-2008, 11:36 AM
What? Do you mean me, or is there another Dietrich on the board?
Do I have an Enzo I don't know about?
When I went through my Spitfire/GT6 period, I could pop those in and out like Pez candies. The last swap I did was on a Volvo 240, pretty easy. About four hours start to finish, including switching the tranny from an old motor to the new motor, and a new clutch, of course. Working alone.
Hot Springs, Arkansas
'87 Graduate
'65 101 Spider
I really miss my TR4A, and my 1800 ES
