I just bought an 1988 Spider with 47,000 miles.
The cylinder head was removed when I bought it.
The dealer diagnosis (they left it in the glove box) was as follows:
- Vehicle towed in – won’t run – function check
- Fuel, ignition, engine
- Very low compression cyl’s 1+2
- Removed cylinder head / analyze engine
- Cam timing has changed- all 4 exhaust valves
- Show signs of hitting pistons – strongly suspect
- Failure of auxiliary timing gear
- Exhaust cam has bad lobe #3 cyl
- ______ valve seat sunken deep into head
My question is this.
What can I do for the sunken valve seat?
I can easily replace the cam and valves.
I want to get the car running before I spend more money on it.
Should I jump in and buy a rebuilt cylinder head or just fix the things wrong with mine?
The car has such low miles I wouldn't think that the engine has much wear.
