Lefty loosey, righty tighty
You'll find that it'll be almost obscenely tight BTW. Lotta folks just brace a heavy breaker bar with appropriate socket on the garage floor on the driver side, then with the coil unhooked and trans in neutral, bump the ignition key and let the starter motor do the work for them.
