In the old days
titanium valveguides were made of barylium bronze.
in the new days
the TI valvesstems are coated with CLD or powerseal
So we don't need to rework the toxic bbronze valveguides anymore.
But nowadays special valve producents make nicro valves so light,
we don"t need to use TI valves anymore.
Not only a hollow stem but also the valve itself is hollow.
About beemer valves they are already 45 degrees,so it will put you 1 step forward
Personaly i would not go smaller than 8 mm, stemwise.Shifting and piston valve contact is more common than you think.
