11-06-2009, 04:04 PM
Trained Professional
Back in the dark ages, I was wringing a stock 1750 GTV around Lime Rock Park for all it was worth. And there was absolutely NO WAY that this thing would go any faster without more horsepower. Lacking the means to effect a power increase by the afternoon session, I decided to experiment with different turn ins and breaking points. Result? 3 seconds a lap faster. THREE SECONDS!!
The moral here is the single most important thing needed to go faster is to improve the nut behind the wheel.
Series 1 Euro 1750 GTV
Series 2 USA 1750 GTV
Series 3 Spider Veloce
11-06-2009, 04:10 PM
Location: NYC, NY. The Spider resides on Shelter Island, NY.
The moral here is the single most important thing needed to go faster is to improve the nut behind the wheel.[/quote]
Agreed. Learn to Heel/Toe or take a session at a driving school, etc. I remember, not fondly, being clobbered at a Road Atlanta track day by a lightly modified Volvo 240 wagon. Never again.
1975 Spider (Long gone gateway drug)
1983 Spider (Dead: slowly parted-out on eBay)
1974 Spider (Body restoration only took 14 months  , now undergoing wallet evaporating full mechanical rebuild)
11-06-2009, 08:43 PM
Originally Posted by Gubi
They're junk. They don't filter well and a lot of dirt into your engine for virtually no power gain. If you do a search you'll find plenty of reasons not to use them.
Some example filtration results here:
Technical Articles: Debunking the K&N Myth - Why OEM is Better
There's a similar analysis on bobistheoilguy.com, and many more if you look around. If you think a 0.06 PSI pressure drop change (that's 0.4% of atmospheric pressure) is going to give you any measurable power gain you're fooling yourself.
I don't want to get into a huge tech argument, being the new guy on the board and all.
The OP asked what could be done to increase HP. Having to ask such a general question in the first place suggested to me that he wasn't particularly knowledgeable of how to modify engines. So I offered a rather simple suggestion that I thought anyone could accomplish.
Do K&N High Flow air filters remove as much from the air as a normal paper filter? Probably not. But that's how they increase air flow into the engine, which has long been recognized as a very basic way to increase HP.
Is the increased particulate intake into the engine going to cause a catastrophic failure? No. Will it increase engine wear and reduce time between rebuilds? Theoretically, yes. But the same could be claimed of almost ANY performance modification. Practically speaking, in normal street use, I can't imagine using a K&N filter instead of a Fram causing any real problems...
11-06-2009, 10:53 PM
I understand engineering tradeoffs. If you read the analyses, however, you'd see that the increase in dirt is substantial and the increase in airflow is next to nothing. If you base the decision on data rather than marketing, it becomes clear that the oiled filters are not a smart choice.
If you search around the web you'll find plenty of folks who have had dirt and oil buildup on their intake hoses and MAF wires after switching to oiled cloth.
1991 Spider
1987 Milano Gold
11-07-2009, 08:04 AM
OK, Tom. Like I said, I don't want to get into a big argument about it. So I'll just concede the point.
So, what's your suggestion to the OP for increasing HP in his '84 Spider?
11-07-2009, 08:36 AM
No doubt you are getting very good advice on this thread from some of the most knowledgeable people on this board. Period. That said, new or old, you should always feel free to speak your mind. I am no expert on the efficacy of these filters either, but you certainly get more induction roar from these air filters, and arguably, a couple of horses. Cheap thrills? Sure, but so what. I had a K&N on my 83, and enjoyed it. There I said it. Bring on the pitch forks.
11-07-2009, 08:50 AM
Member
thanks guys
Hi, to all you
Wow did i get something going or what!!!! Look folks my thing is that the alfa engine is a dam good engine. It is a pity that not much research has been done on improving performance on an engine that can do so. My argument here is that you see many cars be it Porsche, Ferrari, big block Chevy or Fords that even though they have huge engines they are 100 percent smog legal. I mean Ferrari for one has a huge engine that is smog legal. They had to have had some means to produce the type of power that they do and still keep the dogs at bay. All i was looking into is that on an Alfa there has to be a way to increase up to 10-40 hp more without compromising safety or the engine and still stay Smog legal. Thanks for all your replies.
I wish someone out there would find a way to give more power to an engine or develop things that can be done for a great engine.
11-07-2009, 09:16 AM
Darth Slacker
Archangel, you're fine, honest. Denny you too. Nobody should ever worry about 'being the new guy' onnaconna everyone has something important to offer regardless of how long one has been around or what thier postcount is. Remember, we all started at '1'
Sometimes these topics take a bit of a tangent is all, but in a twisted sort of way, it is all relevant.
That being said:
10-40bhp isn't going to come with something so simple as a filter, oil viscosity, or even black paint, especially when emissions considerations are thrown into the mix.
Even more difficult if you're dealing with the EFI versions. (the ECU's are not, shall we say, 'condusive to alterations')
Now an intake cam change can give a fair bit of poke and still retain smog well enough, as can certain camshaft pairs. Even an aftermarket ignition can wake things up a bit, particularly on L-jets.
Probable biggest bang for the buck that doesn't require extensive mechanical knowledge:
Free flowing exhaust consisting of either a header or S2 manifold, modern free flow catylitic converter (very inportant), and the loss of the 3rd can in the system. (center muffler can be improved certainly, but stock is actually pretty fair. The 3rd can doesn't really do anything but dampen resonance a bit via restriction)
Not uber cheap, but relatively easy to do for the not so mechanically inclined who's equipped with minimal tools and will certainly give a noticable punch from the 1st time you drive it boost across the RPM range with the most noticable improvement in the upper half of the tach swing.
11-07-2009, 09:59 AM
Technically speaking, there's not much you can do to increase power while remaining CA smog legal. The laws are pretty strict on modifications. That being said, I know quite a few modified cars that pass smog: you just can't go nuts about it.
10-40 HP on a 120HP engine ain't going to be cheap or easy, though. You might want to start by taking a look at Jim Kartalamakis's book on the Alfa DOHC engine.
1991 Spider
1987 Milano Gold
11-07-2009, 05:42 PM
Richard Jemison
Calif performance
There are cams designed to make far better Torque & HP for the FI cars. And work with the unmodified L-Jet system as long as it is operationally correct.
But you don`t change just the intake.
I can email info if you send me an email.
No PMs
Richard Jemison
RJR Racing
http://scuderiagiallo.com
11-07-2009, 06:56 PM
Hi, to all you
I know nothing at all about California smog laws, so I can't comment on how to stay with the limits. I'm not really familiar with the specifics of Alfa engines either.
However...
There are certain universal things that one can do to most any engine to increase HP. These improvements are usually seen in "stages." You might here references to "stage 1" or "stage 2" or "stage 3" or "stage 4". The higher the number, the more extensive the work and the higher the HP. It's the same types of things that they do for Porsches, Ferraris, Fords, and Chevys.
Basically, you can improve the exhaust system, improve carburetion or FI, modify the cylinder head, and put in a performance camshaft. With the exhaust, FI, and cylinder head mods, you're basically trying to maximize the efficiency of the airflow thru the engine. Reducing backpressure on the engine from the exhaust. Smoothing the intake of air by flowing the cylinder head - air turbulence can reduce HP. How far you go depends on how much of the work you can do (or afford to pay someone to do) and ultimately how much more HP you want...
11-07-2009, 08:24 PM
Do you own an Alfa Romeo?
79 Spider Veloce
85 GTV6
88 Milano Verde
88 Milano Verde
