06-30-2009, 02:26 PM
set the distributor
can some one tell me how me how the distrib, is suppose to sit, as far as in time,
i took it out and the mechanic has no idea on how it should be postion, there no marks
thanks
07-02-2009, 06:51 AM
From the files of the 750-101 discussion group on Yahoo, this link might be helpful (if it works). It's a Powerpoint file showing the orientation of the distributor, rotor and the drive coupling on the end of the distributor:
http://f1.grp.yahoofs.com/v1/UK9MSvU...ual%20Aids.ppt
62 Giulia Sprint
65 Giulia Spider Veloces (two)
88 Milano 3.0 L
91 Ducati 900 S/S
06 Ducati Paul Smart 1000
07-02-2009, 02:34 PM
that link is broke it said
07-02-2009, 04:12 PM
 which car
If you just took Dist. out it only goes back one way!
Of course some models differ!
07-02-2009, 04:17 PM
I am so amazed that you guys post questions like your Alfa is the only one everbody has and we should know what model you are talking about so no brainer just set dizzy such a way and all engines will run perfectly.
Virginia Beach, VA
s.patchin@aroc-usa.org
http://www.aroc-usa.org/
Daily drivers: USA models 91 "Bianco" 164B 5-speed - ALFISTO, 91 Argento aka "Quik Silver" (daughter's) 164B w/AT 1QUIK AG
Winter Sleepers: 93 "Rosso" 164L 5-speed; 91 "Old Blue" 164L w/AT
Rescue projects: Newbie 91 164L "Black Beauty"
Organ Donor 91 Old Nero 164L
SOLD 91 Argento 164L w/AT aka "Quik Silver 2"
07-02-2009, 06:12 PM
Looking at some of your older posts I surmise that you are talking about a 2 liter. The dizzy only goes in one way. If you look at the bottom you will see a key that sits in the slot at the bottom of the distributor hole. Look a little closer and you will find that the key is slightly offset. With a proper O ring seal on the dizzy shaft, insert the shaft in the hole and push it down until it bottoms out. Then turn the distributor rotor while pushing down slightly and feel for it to drop down and engage the mating slot. That's it. I'm a little surprised that your mechanic wouldn't have known that.
Ok, now that I've answered your question I would like to request that you try a little punctuation and grammar in your posts. Us old guys have a hard enough time reading the small print without having to guess when a sentence starts and ends. It's not texting...
- Rich D.
I like Alfas
07-02-2009, 06:31 PM
Trained Professional
Update.
Spoke with the experienced mechanic (VW, not Alfa) this AM to review the oil pump installation (as part of engine assembly) so the dizzy could be installed in the proper orientation.
Series 1 Euro 1750 GTV
Series 2 USA 1750 GTV
Series 3 Spider Veloce
07-03-2009, 07:52 AM
Papajam you are a good man!
Funny, there should be a 50/50 chance getting the water pump oriented correctly (or more since some should know how to install the pump) but I swear 90% of the time I find them 180 degrees off. It bugs me but not enough to tear them apart just for that...
- Rich D.
I like Alfas
07-06-2009, 05:02 AM
thanks papajam, and for my grammer some one, GET f@@@@@@
07-06-2009, 06:03 AM
Originally Posted by goodllookin1722
... and for my grammer some one, GET f@@@@@@...
Man am I glad people like this are in the minority around here...
- Rich D.
I like Alfas
07-06-2009, 07:16 AM
I do agree.
Salutations from Germany
Bernhard
07-06-2009, 10:24 AM
u know this is a awesome bb. im not here to criticize people for there mistakes and so forth, i guess in all cases there are some bad with the good, the people who have help me know what i am talking about,and well u have a good day, comment all u like
07-09-2009, 02:20 PM
Be careful inserting the diz into the oil pump slot. the piece on the end of the diz that fits into the oil pump drive CAN fit 180 degrees out of place. It does fit better one way than the other, and you can feel that. Do it wrong and it WILL add side loads to the oil pump drive shaft, and eventually break it.
And leave you stranded in the worst part of San Jose at 11 pm where even AAA will not come to get you.
It is (was) NOT funny. Quit laughing at me.
Robert
07-09-2009, 02:59 PM
If you put it in 180 out the car will not run(unless you feel upto fliping wires around) But it only fits one way unless you use a hammer(in your tool it)
or crank the dizzy nut down to make it work ,but then it should not start!
No criticizum just trying to helpguess I have to be there
Peace 1722
Past  1960 Sprint,1967 Spider,1969 Spider,1973 Berlina, 1973 GTV,4-1974 GTV's,2-1978 Spider's, 1979 Spider,1980Spider,1981 Spider ..Present= Always Looking For Another
07-09-2009, 04:03 PM
Did this when rebuilding, so the wires were new and newly installed.
General guidelines: Front cam lobes pointing outward (TDC), Distr rotor pointed forward, #1 wire at this point.
I actually had to put the diz drive piece on the diz shaft 180 deg out of phase to get it to fit just perfectly wrong.
And then it worked just fine for several weeks.
Until.......
R
You never learn from success. You just keep making mistakes until there is nothing left but the right way.
