With a 1300, 101 or 105, BREATHING IS EVERYTHING! Correct cams, (from Richard Jemison) matched to a porting job is where most of the top end HP live. A 1400 cc kit is nice, but IF you want a 1600, BUY one. Much cheaper. The same is true for a 1750, or 2L.
IF YOU WANT a 1300, the overbore MUST BE within the design limitations of the 1300 head combustion chamber, which is SMALLER than the 1600 or 1750. For example, a 1600 can use the 80 mm pistons of a 1750, but beyond that, the combustion chamber is too small unless considerable and expensive machine work is performed. Cheaper to use a 2L. The same is true for a 1300. A 2 mm overbore works fine, beyond that, you will begin to need machine shop work on the combustion chamber. These are the design limitations of these engines, UNLESS you are, or know a skilled machinist, who will work cheaply to re-engineer the design. It all depends on what you REALLY want to do, AND how much you are willing to spend. Boring liners is much easier with an Alfa than opening up the block for larger (and too tall!) liners. If you don't like the 1300, GET A BIGGER ENGINE!
 Gordon Raymond
Now:
