After performing several searches on the cross drilling of Nord style blocks I found several threads but no real DYI information. Everyone seems to know what is done but nobody has said how it is done?
Over the weekend I dug out a big right angle plate in my tool crib and machined 11mm holes into the vertical section that are the exact center to center spacing of the main bearing caps. I then removed the caps and used my Snap On stud remover tool to remove the main bearing cap studs.
The studs are 10mm but I made the openings 11mm to allow some movement to indicate the block level.
The first photo shows the block upside down and the angle plate being attached. I used four 10 X 110 X 1.50 bolts that threaded right into the threaded bosses that the main bearing studs did.
The second and third photos show the plate/block mounted in the Milling machine. After calculating the bearing centers I realized that standard jobber length drill bits would not go deep enough to do the job. I am drilling a 4mm passage way because that is what I measured as the feed diameter to the existing Mains.
I have never done this before but I decided to document this project and hope that others join in with questions and comments?
David
