Old 10-09-2008, 12:04 PM
fgc fgc is offline
Help - Drilled Oil Passage??
Hi All,
I am rebuilding my 1750 engine for the first time. So lots of questions to ask
I noted 4 drilled passage on the short block.
1 on the oil filter side see pic 1 below and 3 on the carbs side. These 3 are inline - 2 at each end (pic 2 and 3) and 1 in the middle (no pic).
Any ideas what are they for?
Appreciate your opinions and on what I should do with them.
cheers
Fgc
1750 spider
Before this tear down, my engine had pretty healthy pressure... that is ... if that gauge can be trusted
Then again, my main and big end bearings are quite badly scored. So is that a sign of bad pressure or just simply horribly dirty oil with ineffective filter? (don't know when it was last rebuild - probably at least 15 years back with perhaps at least 100k on it?)
Old 10-12-2008, 08:11 PM
Gordon Raymond's Avatar
Gordon Raymond Gordon Raymond is offline
Perhaps someone drilled them at an earlier rebuild to clean the passages. All manner of strange stuff gathers in the dead ends of the passages.
Gordon Raymond
Illinois SNO Chapter DIRECTOR
