Headers No. 3 (116)
These ones are for a tarmac rally Alfetta GTV. The headers that were on it were cheap replacements of the standard two piece deal. I would guess they were robbing 5 bhp from the engine over the standard Aussie spec headers.
A few problems with standard set-up is that the front secondary (that runs in front of the LH engine mount) gets biffed regularly on lowered cars and ends up flattened. Another is that the primaries are hard to get the right length (16-18") in this configuration (I think standard are about 12-13"). And lastly, the secondaries are unequal lengths.
So this was my solution: Same flange and stub set-up as the 105 headers with correct exit angles, but swept up and around progressively front to rear so that all are ~16". There is a small heat shield over the rubber engine mount as they run pretty close.
There is a flange to join the primaries to the secondaries and the secondaries bend around the rack cross-member. The result is lots of clearance at the front of the engine, and the secondaries are equal length.
There is also a vibration absorber aft of the bell housing extension. These engine vibrate a hell of a lot and few exhaust builders these days hang the exhausts to absorb the resulsant resonances at the rear of the vehicle (therefore fatigue crack-city). It is very hard to hang them with soft hangers (like Mr. Alfa did) when you have a humungous system running in the space designed for something much smaller. Therefore, the rear of the exhaust is quite rigidly located and the vibration is absorbed by the thing-do-hicky.
Departed: 1967 GTA Junior replica (T-S engine), 1966 1600 GTV, 1973 2000 GTV, 75 T-Spark (2), Alfetta GTV (2), 1986 33 4x4 Wagon, 1985 33 TI, Alfetta Sedan (5), 2000 Berlina (2), 1970 Guilia Super (2000), Alfasud (2)
Now: 2006 Subaru Forester
Dreaming: 1985 Alfetta GTV T-S or 1976 Alfetta GTAM
Reason: Fix pics
