05-13-2008, 08:43 PM
mega squirt walkthrough
can anyone point me towards a 'walkthrough' for installing a megasquirt into a 3.0lt 75 please.
other than mega squirt, is there a better way of getting rid of the
AMF?
thanks
1978 116 gtv
1988 3.0 75
05-13-2008, 10:06 PM
Slacker
SDS and Autototronic are a couple of options.
More pricey as they are complete setups though.
There's several others also, but those two came to mind first.
05-13-2008, 11:17 PM
Take a look here:
ALFAGTV6.COM ~ View Forum - MegaSquirt Fuel Injection
I put an MS in my 3.0L Verde and got it idling but didn't have time to further tune it before my track events started up last year so I removed it and haven't gotten around to putting it back in yet. Currently building a 3.0L with S Pistons and more aggressive cams and eventually headers. Plan on putting the MS in again once the engine is broken in so I can get rid of the AFM.
Kevin
86 Spider Veloce
87 Verde
Milano registry custodian( www.alfamilano.com)
05-14-2008, 12:45 PM
there is the post I did for a VEMS install
VEMS Install on my verde
1987 black Milano Verde
1972 White spider 2000 Veloce
05-14-2008, 07:32 PM
I am going to install on in my 200hp 1987 Veloce within the next few months. I've got a thread "Danyl's Yellow Spider" I should be posting my success and failures with the system come August.
I've already read the "MegaManual" a few times through. It seems fairly straight forward for the 2.0 L engine.
I did some considerable research and decided it worth the try. The Autronic looked like my next best choice, but the price difference is substantial.
Daniel
Danyl
1987 Spider Veloce, first and only owner...
05-14-2008, 07:57 PM
Daniel:
I look forward to reading about your project. I too have read the MegaManual, and agree that it seems straightforward. The biggest challenge with an Alfa would be the induction system. Do you plan to use a modified Spica manifold, or Weber-style throttle bodies bolted to a carburetor manifold? The Spica route seems much cheaper, though no one has published much on what type of injectors would fit a bored-out Spica, will provide a workable spray pattern, and of course, have the correct lbs fuel/hr rating.
You may not be prepared to answer this until August when your project gets underway.
'63 Guilia spider
05-15-2008, 12:44 AM
Not meaning to hijack this thread, but I have already made a plan thanks to considerable input from many on this web site.
The SPICA is a very viable option. Many people have gone that route. The Bosch system apparently is improved dramatically with Megasquirt, but is still limited by the manifold and throttle body size. Msiert's Black Spider uses some really exciting individual throttle bodies. That's what I'm shooting for. I'm going to install my Megasquirt on my existing Bosch system first, get the bugs out, and then build the ITB system and re-map the megasquirt. This way I take the project one step at a time.
Now back to our regularly scheduled programming...
Danyl
05-15-2008, 04:20 AM
There is no real walkthrough with MS because everybody takes a different path.
If you stick with the stock hardware it should be pretty straight forward except for the fact that you need to allow for a flyback circuit due to the low impedance injectors. Or you can just use in line resistors.
EDIS6 ignition would be a worthy and relatively inexpensive addition.
Plus a wideband O2 sensor to make tuning easier.
The above is the way I'll be going when and if I get around to replacing the 4 banger with a V6.
Bye for now.....
Brett.
05-15-2008, 04:11 PM
Jay, here's a post from Richard a few weeks ago showing his modification using a Bosch manifold. Compared to the cost of the Jenvy or TWM Weber style t/bodies, this seems to be an effective and cheaper approach.
(Sorry, I couldn't get the photos to copy. You'll have to search for Richard's post.)
#12 (permalink) 03-02-2008, 07:27 AM
Alfar7
Richard Jemison
Spica Performance
Eric, How large are your Throttle Bodies? I know Wes list 40s(mm), but are yours bigger.
Below are the 43.5s I built to attach to a modified Bosch manifold to use EFI easily.
The brass bullerfly laying in one port is a 40mm for comparison...
Rj
Richard Jemison
RJR Racing
RJR Racing specializes in Alfa Romeo Automobiles
'70, 1750GTV, 2nd series
05-29-2008, 10:59 AM
Hi Jazig,
Try this read by Steve Rosser Building a Megasquirt
Peter Web was another Alfa Pioneer with the Megasquirt back in the day. Might want to try a couple of searches that way as well.
Good luck & don't forget to post your results,
07-15-2008, 02:11 AM
Originally Posted by ToonRboy
Link no worky...
-RGK-
[SIZE="1"]-1974 Alfa Romeo Spider (still working on it)
-1980 Volkswagen Scirocco (Bone stock & original, 51K miles...)
-1987 Volkswagen Scirocco 16V (2.0L, Nothing stock or original)
-2003 Volkswagen Jetta TDI (Saves me money for the above)[/SIZE]
07-23-2008, 05:59 AM
Works for me. That is the article I used as a reference when building my MS.
alfagtv6.com MegaSquirt Article
Kevin
86 Spider Veloce
87 Verde
11-24-2008, 06:28 AM
Speaking of throttle bodies... any thought to using motorcycle throttle bodies? There's plenty of fuel injected motorcycles these days, with most of them running between 750cc and 1000cc inline 4s. The diameter to the throttle bodies should work well on a 2000cc inline 4.
11-24-2008, 11:19 PM
Lots of have and they can work well if you are handy with adaptation.
Definitely not a bolt up option.
Most are probably a little too big for even a 2L. Mine are off a 600/750cc bike and are a little oversized. This makes them a little difficult to tune on a speed density system like MS, because open the throttle 20% and no more vacuum to work with.
Bye for now.....
Brett.
11-25-2008, 08:13 AM
can anyone point me towards a 'walkthrough' for installing a megasquirt into a 3.0lt 75 please. other than mega squirt, is there a better way of getting rid of the AMF?
I'd ask jazig.k why he want to get rid of it & what other mods he's got. Is this a street or track vehicle? If street, does he need to drive the car in question any time soon? Also, what's the weather like where he lives? Is it like San Diego, or Like Rochester NY? -Will make a huge difference on how much time he'll spend massaging that (whatever brand) ECU.
Everybody wants Throttle Bodies these days. For the time and effort tuning an engine fitted with them, I'd design and build a variable intake manifold instead.
For guys that need a walkthrough on getting rid of their AMF, I'd recommend the Split Second solution. That way you can keep all your stock sensors and ECU, open-up the intake (presumably what they're trying to do), and add programmability (if PSC used).
