Old 03-20-2008, 12:16 PM
Caster56 Caster56 is offline
carbon deposits expelled from tailpipe
I just traded my 1971 Berlina for a black 1971 Spider, the Spider runs great, but has some difficulty starting, the choke cable only pulls out about 1/2 inch (is this normal?) also there is a black residue inside the tailpipe and when car is initially started from sitting overnite, this semi- oily(has a slight gas smell) black residue is sprayed on the driveway, not a great amount and it quits after car is warmed, could this be a lean fuel mixture that I could correct by adjusting the cut-off solenoid, or could this be a harbinger of worse problems to come? Any help would be appreciated, Tom
Old 03-20-2008, 12:34 PM
ossodiseppia's Avatar
pffffffffffffffffffffff!!
That's just condensation mixing with the soot in the exhaust. It's nothing to worry about.
Old 03-20-2008, 12:47 PM
Bill S Bill S is offline
A Spica equipped car would not normally have a choke cable. Perhaps you have a Shankle Sure-start that has replaced the thermostatic actuator? I don't think they have much travel in the cable. You may want to check your spark plugs for carbon to see if your Spica is adjusted too rich. Otherwise, yeah, the soot spitting is usually just from condensation in the exhaust as Osso stated.
Bill Sinclair
67 Duetto
69 Berlina (project)
73 GTV (project)
Old 03-20-2008, 12:58 PM
lowmileage's Avatar
ReAlfisted 3/06
You say cut-off solenoid so I assume it has Spica injection. If so, repeat after me - I will not mess around with the Spica system until I'm completly knowlegable with the operation of it which means I have read Wes Ingrams manual, and all of Roadtrips postings
I wouldn't be too concerned with the "dirtyness" of it at start-up, heck even mine does it.
1973 GTV - bought 3/06
1969 GTV, #AR1530021 - sold 10/72
Old 03-20-2008, 01:07 PM
Thanks for the help, and No I will not fiddle with the SPICA, learned my lesson with that long ago, but I do know a mechanic who could do it if it needed it.
Old 03-20-2008, 01:13 PM
I didn't think the 71 Spider 1750 had a choke, and the thermostatic actuator is still on the SPICA, the guy who traded the Spider for my Berlina called it a choke and it won't start in the AM unless you use it, its located at the rear of the console behind the cig lighter.
Old 03-20-2008, 01:22 PM
lowmileage's Avatar
ReAlfisted 3/06
Just make sure the mechanic dosen't look like this one.
Old 03-20-2008, 01:25 PM
Is that Jennifer Lopez?
Old 03-20-2008, 01:34 PM
lowmileage's Avatar
ReAlfisted 3/06
Close, but her name is Jeffiner Lowpez and she told me that she is the ghost writer for many Spica books.
Old 03-21-2008, 11:06 AM
Zunige's Avatar
Zunige Zunige is offline
In the Spiders' nest...
The OEM SPICA set-up has a "hand throttle", which many confuse for a choke. It is exactly as you describe. In order to start a SPICA car, one should really turn the key on without starting the car, in order to allow the fuel pump to come on. The pump noise is audible, and the red low pressure indicator light on the dash will come on, and go off when pressure exceeds 7 psi. That's the point when the key should be turned to start the car. Starting the car still requires that the gas pedal be depressed part way. The hand throttle is used to set the idle higher, which is sometimes needed while the car is warming up...
The black soot spewing during warm-up is absolutely normal in all Spiders. There are several threads about this, some with pictures...
Best regards,
Enrique
Spider 74, 84 & 87
164 93L & 95Q
Milano 88 Verde
