#46 (permalink)
Old 09-02-2008, 06:26 PM
slyalfa slyalfa is offline
"pressure transducer spark plugs"
Do you know where to get some and how much?
I have not been able to find a small pressure transducer my self to make my own.
I thought I might be able to use a watch crystal but it seems to not notice pressure but did show shock.
I was thought it might work and is the right size to fit in to a spark plug.
in the lab busting in 135PSI into the can did not show anything but tapping on the can did.
might still be fun to try one. I bet it would pick up det real well.
1987 black Milano Verde
1972 White spider 2000 Veloce
  #47 (permalink)
Old 09-03-2008, 05:43 AM
turbolarespider turbolarespider is offline
We use products from Kistler. And you need pressures up to about 5000 psi, so that you know the probes wont break.
Eric
  #48 (permalink)
Old 09-03-2008, 12:46 PM
I looked at there web page and could not find any sparkplugs type or a tiny one I could add to a sparkplug.
do you have a part number?
  #49 (permalink)
Old 09-03-2008, 01:17 PM
Sorry- they don't do spark plugs- they do the high speed pressure transducers. I'm not sure who fabricates the plugs- but we just put a small metal hose from the transducer to the metal part of the plug that, deep enough to get in cylinder pressures.
Not all that durable- I think we keep the milage to under 100 for a car, or the dyno isn't an issue- easy to replace.
The far better option is to install the transducers in the head. Expensive, and again, not all that durable.
  #50 (permalink)
Old 09-03-2008, 06:19 PM
hmm I guess the tube is so small it does not change anything. like a pin hole in size I guess.
google showed a few
PSIplug & CALplug
PIEZOCRYST: Advanced Sensorics GmbH - Pressure Sensors
The last time I searched I could not find anything other then a pic of one. now there seems to be a few making them. but I have not got any pices yet. I saw a post on a other forum that said over $1000
I hope to find just the transducer plug for a lot less than that. but if not I might try the small hose trick.
I think no mater what it will not last long so somthing cheap(r) would be best.
