Pertronix Ignitor on different Bosch distributor - Alfa Romeo Bulletin Board & Forums
post #1 of 7 (permalink) Old 11-16-2016, 01:30 PM Thread Starter
I bought an Ignitor for my Bosch distributor a while back. When restoring the distributor, the Ignitor seemd to be for a different Bosch-unit, as the mounting holes were different. I managed to adapt the Ignitor to the distributor, adding a mounting hole for the unit. I have been having some trouble starting the engine since the complete engine rebuild. I am getting a spark, but I am wondering if it is possible to get a weaker spark if the ignitor is mounted a degree or two off?
thisquietplace is offline
post #2 of 7 (permalink) Old 11-16-2016, 01:41 PM
Jim G's Avatar
Its probably out of phase. You can send the whole dist. with the igniter to pertronix and they will adjust into get it in phase. If you don't want to send it. Call their tech line and ask for Carl. He can explain how to do it.
I just got 2 more.
Jim G is offline
post #3 of 7 (permalink) Old 11-16-2016, 02:20 PM Thread Starter
Thank you, if I am going to put any more money into the distributor, I might as well just get a programmable unit, and sell the Ignitor. Will give Carl a call first.
post #4 of 7 (permalink) Old 11-16-2016, 03:02 PM
Alfajay's Avatar
What I think Jim is getting at is that your Ignitor may be placed incorrectly so that it is firing the coil when the rotor isn't aligned with one of the four studs on the distributor cap. That would force the spark to jump a long air gap inside the distributor cap to get to the wire and ultimately to the spark plug.
Most likely Pertronix tech support will just tell you to get the correct Ignitor for your distributor. But you might be able to drill some new mounting holes so that it fires when the rotor is in phase with the output stud. Or just buy a 1-2-3.
'63 Guilia spider
Alfajay is offline
post #5 of 7 (permalink) Old 11-16-2016, 04:08 PM
Jim G's Avatar
The couple of ones that I had to send to Pertronix to have phased. They did it at no charge.
I just got 2 more.
Jim G is offline
post #6 of 7 (permalink) Old 11-16-2016, 04:33 PM Thread Starter
Is it possible to measure the output to the spark plug and compare it to a desired output range, or would I just be blowing up my multimeter? The Bosch is from a 1300, and the engine is a 1750, so I might be better off getting a distributor with an adjustable advance curve either way
post #7 of 7 (permalink) Old 11-16-2016, 08:40 PM
Jim G's Avatar
Phasing is what Alfajay described in his post. I think you can do it with a test light. In the past I've used an old Sun distributer testing machine. Either way you have to have a battery and several wires hooked up.
Call or email Pertronix. They can tell you how to check the phasing and should be able to give you a diagram on how to hook power up to the igniter and teat it.
I just got 2 more.
Jim G is offline
