As Tifosi indicated, you can absolutely do this and that is is how you change your ignition. Thus, you can have an aftermarket ignition, with your Bosch L-Jetronic fuel injection. Note that if you buy something like the RML ignition which can be found on the RML web site, and also on the IAP web site, that's how you would connect it. I'm not sure what exactly you are doing, but note that by disconnecting the Bosch Motronic ignition you are also no longer using the flywheel sensors. (Most aftermarket ignitions, if not all, don't use these sensors.)
A word of caution however. As you advance your timing, to take advantage of high lift cams, to take advantage of a better flowing head, etc. you also run the risk of "pinging". So, just take it slow, as you do these mods.
Best regards,
Enrique
Spider 74, 84 & 87
164 93L & 95Q
Milano 88 Verde
