Best way to pressurize Series 3 Lubrication System - Alfa Romeo Bulletin Board & Forums
 3Likes
  • 1 Post By jc96
  • 1 Post By Chizel
  • 1 Post By Richard2
post #1 of 11 (permalink) Old 08-07-2016, 10:11 AM Thread Starter
Firing up a car that has not run for 4 years, best way to pressurize lubrication system prior to firing? Thanks!
warmblood58 is offline
post #2 of 11 (permalink) Old 08-07-2016, 10:14 AM
jc96's Avatar
disconnect the coil lead to the cap and spin the engine with the starter till the guage shows pressure. If u r super AR like me, remove the spark plugs first to ease the work the starter has to do. Ciao, chris
warmblood58 likes this.
Maintaining my tenuous strain on reality.
89 164 2l Twin Spark, 2011 Tonka Dump
Recently added: an 89 75 (Milano) 1.6 litre w/44K on the klok.
Past loves:
79 Alfetta GTV w/Spica, my 1st Alfa
An 88 Graduate. Not really love but interesting nonetheless.
A 68 BMW 1602 - man do I regret letting that one go!
79 Scirroco, ex plowed into an illegally parked house with it...
jc96 is offline
post #3 of 11 (permalink) Old 08-07-2016, 10:18 AM Thread Starter
Thanks, but was hoping for a way to do so without cranking - any thoughts here?
post #4 of 11 (permalink) Old 08-07-2016, 10:23 AM
jc96's Avatar
top of my head, no. Can I ask why? Ciao, chris
Past loves:
jc96 is offline
post #5 of 11 (permalink) Old 08-07-2016, 10:28 AM
jc96's Avatar
read down to building oil pressure section .Sounds like a bit of work but guess it can be done
Tech Article: Bringing a Car Out of Storage
ciao, chris
Past loves:
jc96 is offline
post #6 of 11 (permalink) Old 08-07-2016, 11:32 AM Thread Starter
Sure, instead of rotating parts dry, you can circulate oil quickly through out engine by spinning oil pump only. This is usually achieved by spinning distributor shaft on American cars, not sure about Alfa and thought someone might know of a quick and clever way to achieve this.
post #7 of 11 (permalink) Old 08-07-2016, 11:58 AM
jc96's Avatar
brainfart. I don't think this method can be done on an Alfa 4. Pump is geared. ciao, chris
Past loves:
jc96 is offline
post #8 of 11 (permalink) Old 08-07-2016, 11:07 PM
PSk
Remove oil pressure sender unit. Thread in an adapter that is connected via a hose to an external pump. What that pump is I have no idea, just offering suggestions .
BTW I've just pulled apart my 1750's engine and yes it had seized, but if it hadn't I would not have been concerned about spinning it on the starter as there was still oil on the crank bearings and camshafts. This engine has not been turned for 30 years
With the plugs out she will get oil pressure real quick
'71 1750 Series 2 GTV:
PSk is offline
post #9 of 11 (permalink) Old 08-08-2016, 09:22 AM Thread Starter
Thank you!, interesting thought. I may just pull valve cover and squirt engine oil over valve train and hope the lower end gets what it needs before firing and will pull plugs so it can spin up fast-thanks!
post #10 of 11 (permalink) Old 08-08-2016, 09:44 AM
I pull the coil wire, pull the plugs and shoot some wd-40 down each cylinder then spin the motor up a few times.
IanB likes this.
Chizel is offline
post #11 of 11 (permalink) Old 08-08-2016, 09:45 AM
Go to Harbor Freight and buy one of those little plastic pumps for a drill for cheap and pump oil in the sender as suggested
IanB likes this.
Richard2 is offline
