Old 12-20-2007, 02:24 PM
Chsmadden's Avatar
Chsmadden Chsmadden is offline
Send a message via AIM to Chsmadden Send a message via Skype™ to Chsmadden
Slow oil leak
I have a 1974 Alfa GTV with the 2000 engine. The car has a slow oil leak from the pan and I can't find out where it's coming from nor can I stop it . The engine is running redline 10W30 synthetic. Wherever I park it, it leaves an oily mess. Has anyone else had this problem and stopped it?
Old 12-20-2007, 04:33 PM
Tifosi's Avatar
Tifosi Tifosi is online now
Slacker
How's the front crank seal doing?
If it's weeping or not quite totally shot, it'll fool you into believing it's the pan all day long......
Darren
as hosted by
Old 12-20-2007, 05:00 PM
Chsmadden's Avatar
the engine was rebuilt twice, not by me though, but i believe the front crankcase seal is fairly new
Chris Madden
1974 GTV
Old 12-20-2007, 05:58 PM
msiert's Avatar
msiert msiert is offline
Darkside Member
Is it leaking from the front of the pan or the rear?
I had a leak that looked like it was coming from the back of the upper pan and it turned out to be the rear crank seal. Took all summer to figure it out.
It was when I had it jacked up and saw oil dripping out of the bell housing drain hole that I finially figured it out.
My engine was just rebuilt too.
Murray
1991 Black Spider
The "Black Spider" project
Street Video
Track Video
Old 12-20-2007, 08:07 PM
Chsmadden's Avatar
I don't believe so. When I look under the car, i can see a small droplet forming on the front crossmember.
Chris Madden
1974 GTV
Old 12-21-2007, 06:01 AM
Alfacliff Alfacliff is online now
another source of oil leaks on the front of the engine is the hose from the oil vapor seperator, it runs from the seperator to the dipstick tube, under the radiator. these crack and leak oil all over the front of the engine. at least it did on my 74 spider. also, 10w30 synthetic is a little thin for 4 cyl alfas, please search, you will find a lot of people who have oil leaks with synthetics thicker than that.
cliff
