Vacuum influenced Distributor - Alfa Romeo Bulletin Board & Forums
 1Likes
post #1 of 30 (permalink) Old 11-15-2015, 11:16 AM Thread Starter
AlessandroM's Avatar
Red face Vacuum influenced Distributor
Hey there
I plan on buying a (USB Configurable) 123 Tune Distributor. Upon evaluation i came to the question of whether to buy one that supports vacuum input. Which led me to two (probably initial) questions:
- Is the vacuum relevant if you have a usb-tune? I If there was a slight deviation you could fix it by just retuning (at least in my naive mind ;-) )
- where does the vacuum line get its "feed" from? Can I make use of it even if my current distributor doesn't have it?
Thanks!
Alessandro
AlessandroM is offline
post #2 of 30 (permalink) Old 11-15-2015, 11:58 AM
Gubi's Avatar
I would suggest you get the USB tunable version, and that model has the vacuum input. The stock Alfa curves can be improved upon and the USB model gives you more flexibility whether or not you use the vacuum advance.
If you hook up the vacuum port, you need to pull plenum vacuum or port vacuum from all cylinders (not just from one). This is easy if you currently have EFI, more difficult if you have carbs.
I have DCOEs and just didn't hook up the vacuum port on the distributor: it doesn't really cost you much to not use it.
1991 Spider
Gubi is online now
post #3 of 30 (permalink) Old 11-16-2015, 04:48 PM
For what it's worth, Bruce/Alfanuts green Super has a 2 liter with a European Alfetta Bosh electronic distributor w/ vacuum advance. I was never a fan of vacuum advances because they weren't "performance" distributors. But Bruce regularly gets 28mpg with his "non-performance" distributor and emission Dellortos while, on a good day, I get 21mpg . . . Dammit.
180OUT is offline
post #4 of 30 (permalink) Old 11-16-2015, 05:11 PM
Alfajay's Avatar
AlessandroM: Not knowing what sort of induction you have (single carb, dual carbs, fuel injection, ...) it is difficult to answer your question.
Gubi is right: if you have two sidedraft carburetors with four chokes, you need to take a vacuum signal from all four ports. If you just attach the hose to one port, the distributor gets a "choppy", on-off sort of a vacuum reading. The stock Alfa sidedraft manifold doesn't have a provision for vacuum ports (other than on #4 for the power brake booster) - you would need to add them in some way.
'63 Guilia spider
Alfajay is offline
post #5 of 30 (permalink) Old 11-16-2015, 08:47 PM
This may be an aside but when driving my GTV6 I cannot discern any difference between having the vac line connected to the distributor and having it pinched off. I have now disconnected it and plugged the port on the plenum.
85 GTV6 3L
alfaparticle is offline
post #6 of 30 (permalink) Old 11-16-2015, 10:34 PM
Gubi's Avatar
That's because it's a vacuum advance. It advances timing under cruise or low load conditions to improve fuel efficiency. Doesn't make any difference in power or performance otherwise.
Basically not having it hooked up just means you're wasting gas to no good end. So if you can use the vacuum advance, do it. If you have Webers don't worry about it.
1991 Spider
Gubi is online now
post #7 of 30 (permalink) Old 11-17-2015, 07:49 AM
I will be implementing Megasquirt ignition control which uses MAP and rpm to determine spark advance.
In a high performance engine the vac advance mechanism may be locked to reduce spark scatter.
85 GTV6 3L
post #8 of 30 (permalink) Old 11-17-2015, 09:33 AM
Returning to the original question:
I think that it depends upon what kind of advance curve you plan to use. I have been using the original, non-programmable 123 distributor for 8 years and over 30k miles on two different engines with two different compression ratios and five different camshaft combinations. After much experimenting I settled on curve "D" with 34 degrees of advance, all in at 4000 rpm. My typical cruising rpm is about 3000 rpm where the advance is 27 degrees so a vac advance may give me 7 degrees more advance. If I had a stock motor and I was concerned about meeting emissions standards and/or running on third world gasoline then I might choose curve "A" with max advance of 36 degrees at 5000 rpm. At 3000 rpm the advance is 22.5 degrees and a vac advance may have the potential to give an extra 13.5 degrees of advance.
Clearly the vac advance is more beneficial with a slow advance curve and less so with a faster one.
85 GTV6 3L
post #9 of 30 (permalink) Old 12-19-2015, 03:31 PM Thread Starter
So to sum it up, when you have carbs vacuum advance is quite difficult to make use of. Does that mean 105/115ers were never having vacuum advance from factory?
post #10 of 30 (permalink) Old 12-19-2015, 04:31 PM
Alfajay's Avatar
I don't think the problem is with all carburetors - just with dual sidedrafts (e.g., Weber DCOE's). The difficulty is obtaining a clean vacuum signal from the four, independent chokes.
Alfas with single downdraft carburetors did come with vacuum advance distributors. Old-time American V8's with single carbs commonly used vacuum advance.
'63 Guilia spider
Alfajay is offline
post #11 of 30 (permalink) Old 12-19-2015, 09:18 PM
Push hard and live
DPeterson3's Avatar
Im suffering a bit of bafflement. That's not unusual, but....
Are all of you guys sure about what you're saying?
All of the "vacuum advance" distributors I've known might better be described as "vacuum retard". They would get the maximum vacuum when the throttles were closed, causing the diz to retard from its static setting. This was to improve the idle performance, among other things.
As soon as the throttles opened, the vacuum would essentially vanish, and the advance mechanism would take over just like in other distributors.
This approach provides a wider range of spark timing, with a steep break in the curve at idle, specifically to improve drivability and a smooth idle.
In this system, the vacuum is generally taken just after the butterfly, as one wants max vacuum/max retard at idle. The vacuum port is close to the butterfly so the vacuum doesn't vanish all at once when the butterfly opens (Bernoulli). It works fine on a single barrel of a dual Weber system, if the Weber is equipped with the correctly placed port. Most are not. The DCOMs on my 102 have the single vac takeoff, but I don't use it.
I'm not familiar with dizzies that depend upon vacuum to manage all of the advance. In fact, since vacuum diminishes with increased throttle opening, the kind of diz you guys are describing would have to be set at max advance for static, requiring the "vac advance" pot to kick in pretty quick at the moment of start up.
I suggest further reading.
Don P
Carson City, NV
Past Alfas...
Current Alfas
And past...
1946 Luscombe 8A
And present...
Newest in the fleet
2010 Triumph Thunderbird
DPeterson3 is offline
post #12 of 30 (permalink) Old 12-19-2015, 09:31 PM
Gubi's Avatar
Vacuum advance and vacuum retard are two different things. Some distributors have vacuum advance and some have retard. The Alfa V6 started out with a vacuum retard distributor, for example, and went to a vacuum advance in the later ones (though the advance version didn't pull plenum vacuum, it pulled port vacuum which is slightly different).
My understanding is that the main reason for vacuum retard distributors to exist was to improve idle emissions. That's sure as heck why my TR7 had it. One could disconnect the vacuum retard and retime to Euro specs and you would have the same setup as the cars shipped with outside of California, which sure improved idle and performance.
1991 Spider
Gubi is online now
post #13 of 30 (permalink) Old 12-19-2015, 10:23 PM
Push hard and live
DPeterson3's Avatar
Hubie,
Port vacuum is a variable term. A "port" can be ahead of or behind the butterfly. If ahead of, it will see some vacuum after the butterfly opens, but it's not a strong vacuum. It will never climb very high as the engine revs, and I would think it is of marginal use in diz timing. If the port is after the butterfly, the vacuum is highest at idle, and decreases from there.
I may read up some on this, but I have a growing suspicion a lot of dizzies are hooked up wrong due to how they work. Haven't paid attention to this in many years.
All of these are referred to as "vacuum advance" because vacuum is what controls the advance, but it's an inverse relationship.
Don P
Carson City, NV
Past Alfas...
Current Alfas
And past...
1946 Luscombe 8A
And present...
Newest in the fleet
post #14 of 30 (permalink) Old 12-19-2015, 10:56 PM
Bored Member
jc96's Avatar
interesting discussion. Some light reading for us:
Compression and Vacuum
Personally, I'm looking to buy a similar unit just to mess with next spring. My current factory setup is mech adv and vacuum "influence". I'll buy one with the ability to utilize the vacuum, otherwise bypass it. I at least like the option.
ciao, chris
Maintaining my tenuous strain on reality.
89 164 2l Twin Spark, 2011 Tonka Dump
Recently added: an 89 75 (Milano) 1.6 litre w/44K on the klok.
Past loves:
79 Alfetta GTV w/Spica, my 1st Alfa
An 88 Graduate. Not really love but interesting nonetheless.
A 68 BMW 1602 - man do I regret letting that one go!
79 Scirroco, ex plowed into an illegally parked house with it...
jc96 is offline
post #15 of 30 (permalink) Old 12-19-2015, 11:02 PM
Gubi's Avatar
Nope. Vacuum advance physically advances the timing. Vacuum retard physically retards the timing. They are most definitely not all referred to as vacuum advance, or at least they shouldn't be.
If you look at the two variants of Alfa V6 L-jet distributor, you'll see that the vacuum device is physically flipped. In the early version (plenum) vacuum retards the timing and in the later version (port) vacuum advances the timing. It is most definitely not always an inverse relationship.
For example, the non programmable Alfa version of the 123Ignition looks like it goes from +0 deg at 100mbar vacuum up to +10 deg at 400mbar vacuum. Those are vacuum readings so 0mbar is atmospheric pressure.
Yeah, read up some on this!
rogerspeed likes this.
1991 Spider
Gubi is online now
Replace with
