06-05-2007, 03:17 AM
Programmable Motronic ML4.1 for 75/164
Hi,
I'm currently re-writting the firmware of a ML4.1 box. The goal is to have a more performant and programmable ECU. The first target will be ignition on a Mini engine, but injection will come soon after.
Does anyone know about any similar project ?
06-13-2007, 07:00 AM
This is a very interesting project!! Congratulations
In the end you can program the motronic like a Megasquirt for example?
Good luck
Joćo Martins - #RedAlfa#
Alfa Romeo 33 1.7 16v QV # Alfa Romeo 75 2.0 TS # Alfa Romeo 156 SW 1.9 JTD Mjet 16v
06-13-2007, 08:17 AM
Richard Jemison
programable FI for V6
Yes Al Mitchell has done several. I have one of them. It will control fuel, ign, water inj, nitrous etc.
Richard Jemison
RJR Racing
http://scuderiagiallo.com
06-13-2007, 08:22 AM
Do you now what are the necessary modifications to the original ecu unit?
Sorry, but how is Al Mitchell?
Regards
06-13-2007, 09:21 AM
Could you say more please.
Who is Al ?
Does he sell that ?
Do you have a host software for that ?
Which Motronic did he re-programmed ?
06-13-2007, 09:22 AM
Good luck
Yes. The main reason is that controlling the serie-A Mini engine is very difficult as it has siam ports.
06-14-2007, 06:52 AM
Richard Jemison
Contacting Al Mitchell
I spoke with him wednesday. He is doing fine.
But for those interested in contacting Al, his email is below. He and his wife both race a Alfa GTV6 SCCA E Production car.
As to modifications to the unit for the 12V V6 I am clueless. Anything that flows through a solid is the work of the Devil. I know he writes code for his unit, gave me a laptop with all of the various programs, and instructions how to change the set ups. His car has become a test mule for many of my 6 cyl. cam designs & small 5.5 inch clutch & flywheel, & close ratio transaxles, after I sold the GT2 GTV6.
Email for Al is: allenom@pol.net
Richard Jemison
RJR Racing
06-14-2007, 07:58 AM
Opss... my intension are "but who is Al Mitchell" and no "how"
06-14-2007, 09:17 AM
I contact Allen and what he did was to completely replace the
computer in the ECU box with a Megasquirt computer.
This is a very good solution, because allows use of the stock wiring harness, what is great.
Regards
06-15-2007, 12:39 AM
I prefer to keep the ECU as is, but I'm going to replace the original CPU 8052 with a modern pin-to-pin compatible which has 5 new timers and the x2 performance feature.
Also the ML4.1 circuit still has the additional ML3.1 reference pin input which can be used on the flywheel or as a cam reference sensor.
06-17-2007, 07:17 PM
c501
Hi Alpa
That sounds like a great idea. Are you thinking about changing the 8052 to something like a c501 in the same DIP40 package?
How will you deal with the firmware? Also, do you have the maps for the eprom?
Good luck with this - night be time consuming really cool stuff.
Simon
91 Spider, Dover MA
06-18-2007, 02:01 AM
Originally Posted by Razzo rosso
Hi Alpa
Simon
I bought 15 items of the Atmel TS87C51RB2, it's a DIP40 8052 with all Philips/Temic devices and features. I'm going to connect a RS232 driven backlighted external screen to display real time parameters like RPM, temperature.
Firmware: as mentioned I'm writting my own one. I reuse the Bosch map access routines and their math routines. I have a Linux based Bosch map editor and an Eprom emulator which understands these maps. Their routines are well written and extensively tested (and even certified ).
I'm going to have a configurable real-time kernel (already tested) and a background main calculation loop (engine dependent). But I would not be able to share all that because most of people uses Windoz and does not have ROM emulators. It would be cool someone writes a graphical interface to program the maps and to put them into the internal EPROM through the serial connection. For the moment I don't plan to spend time on that.
06-18-2007, 02:22 AM
Alpa
I am impressed. You have obviously thought this through really well.
Simon
91 Spider, Dover MA
06-24-2007, 09:37 PM
Originally Posted by alpa
Hi,
Did you have to read code out of the 8052 or is all the firmware located in the external EPROM?
How different are the ML3.1 and ML4.1 designs? There are schematics for the ML3.1, any for the ML4.1?
06-25-2007, 01:16 AM
The entire ML4.1 code is outside. Anyway I don't keep it, I just re-use some of their routines (map access, math library).
The ML4.1 schematic is in the File section of Alfa75 Yahoo newsgroup. It's derived from the Opel ML4.1 schematic).
I would say ML3.1 was a trial, ML4.1 was one of first ECUs of the 8052 architecture which is based on the 60-2 pulley (BMW, Porsche, Alfa, Peugeot GTI, Opel (GM) 2L GSI). The difference is in this 60-2 pulley and the way it's used.
The ML3.1 firmware was much simpler but most of basic routines were the same, except the ignition management.
