Old 03-04-2006, 06:09 AM
AlfaGeorge AlfaGeorge is offline
EFI in spica manifold?
Wondering if anyone has tried/succeeded in fitting electronic fuel injectors into a spica manifold? What type of injectors did you use? What type of manifold machining operations were involved? Fuel rail? Did you use megasquirt, haltech, electromitve, etc...? How did/does it run?
Old 03-06-2006, 04:19 PM
catsboy's Avatar
catsboy catsboy is offline
Professional Amatuer
Hello...
Has anybody done this? Doesn't seem (famous last words) that complicated...
Richard
'87 Milano Platinum (daily driver & concurrent project)
'79 Alfetta (track project)
More, but currently not viable...
Old 03-06-2006, 07:41 PM
slyalfa slyalfa is offline
The spica injector looks very long.
I am going the other way I am adding a servo system to control the spica pump with a ECU.
but Jr. over at APE milled a spica Montreal v8 to take normal E-injectors.
1987 black Milano Verde
1972 White spider 2000 Veloce
Old 03-06-2006, 11:10 PM
bianchi1 bianchi1 is offline
Talking i have looked into it...
i am trying to design a manifold to the ind. intake runners of the spica........to fit the l-jet injectors should not be too hard( i think) just need to weld some bosses to hold the l-jet injectors down, going to buy some of that alumin -weld, they say it is harder than the alum. that you weld it to.....but you must wait, this well be a late spring sumer project, sorry, but e-mail me if you like.
Old 03-07-2006, 12:40 AM
sono veL.O.ce's Avatar
sono veL.O.ce sono veL.O.ce is offline
slyalfa,
I am EXTREMELY interested in your servo controlled SPICA. Would you mind creating a post detailing it?
[SIZE="1"]'66 [COLOR="Red"]GTV [/COLOR] rolling chassis --- '74 [COLOR=SlateGray]spider[/COLOR](heirloom) --- '64 [COLOR="Silver"]Giulia Ti[/COLOR] --- '74 [COLOR="Blue"]GTV[/COLOR] sold! --- '74 [COLOR=Red]GTV[/COLOR] sold!
'6x DUCATi 250cc cafe racer.[/SIZE]
Old 03-07-2006, 04:45 AM
marco/hamburg's Avatar
marco/hamburg marco/hamburg is offline
I did it and it works fine but it needs a little bit work (Drillingmachine, Welding)
Marco
Old 03-07-2006, 05:41 AM
VeniVidiVeloce
Guest
Posts: n/a
Jim Steck can convert yours, he did mine and others.
www.autocomponenti.com
-Brian
Old 03-07-2006, 06:33 PM
Originally Posted by sono veL.O.ce
slyalfa,
I been waiting for Wes to send me a pump. but it been taking too long. So I took off the pump off my car(I wanted to keep it runing )
I just started to take it apart last night. it was starting to act strange anyways.
what I would like to do is add the TPS and the triger wheel inside too.
I use pump wheel now for the trigger wheel and it works well.
as you can see I liike to try to keep the look stock looking. the biggest give away will be the lack of a dizzy
Old 03-07-2006, 07:00 PM
marco/hamburg
How do you have the knock mounted? and does it work well. And what bandpass do you have the knock filter set to(if the ECU you use let you set that)
Old 03-09-2006, 04:26 AM
Originally Posted by slyalfa
marco/hamburg
you have to Drill a hole for 8mm thread approximately 40 mm deep. But the result was not really better as before. After I take a piece of “Teflon” under and the knock sensor works a little bit better.
Today I work with a free ECU and from that time my problem with this thing is gone.
But to tell you the truth the right setting for the knock sensor ( ECU setting ) is until today not really ready.
I will do it in the summertime.
Old 03-09-2006, 12:26 PM
drilled into the head? no problem of making a hole on a coolent passage or oil passage?
I was thinking if puting it on a strap like the lifting strap .
and where did you have it before?
BTW I am a VEMS developer.
Old 03-15-2006, 12:45 PM
don't worry about it in newer heats there are some, howe to say, a extra Place for what ever.
take a look:
in the middle of the intake mainifold
greetings marco
Old 03-15-2006, 10:16 PM
hmm my 72' head has no place like that. I guess I will try elsewhere.
VEMS Versatile Engine Management Systems
it is a car ECU www.vems.us
  #14 (permalink)
Old 04-12-2006, 10:59 PM
karmat's Avatar
karmat karmat is offline
There was a discussion about using SPICA manifolds for EFI some time ago on the Megasquirt board. The general consensus was that while it does work, the angle of the injectors is sub-optimal for EFI. Probably will never matter to anyone who is doing this but just thought I'd throw it out there. Something to do with the difference in pressure from the SPICA pump vs the EFI. The injector angle for the SPICA was designed with one pressure in mind and the EFI uses a I think lower pressure.
All that being said, I have seen the setup that Jim Steck did on Ken Wears' car and it is a work of art. As is the one on Brian's car.
Karl
[B]Have:[/B] 1969 1750 GTV under restoration
1969 1750 Berlina
1968 Giulia Sprint GTV (very rough, no motor)
[B]Had:[/B] 1982 GTV6 3.0 w/4.10 rear, Stebro (imported engine from UK in 2002) -- Rear-ended 8/2004.
1988 Milano Verde
[B]Non-Alfas:[/B]1984 Volvo 244
  #15 (permalink)
Old 04-13-2006, 06:19 AM
turbolarespider turbolarespider is offline
Karl
It's an interesting comment coming from the MS board. IF MS was truly sequential, then the difference may actually make a difference. From what I know, the SPICA injector does point at the back of the valve, which is a very good spot to inject fuel, in my experience. Other than that, it may be the tip intrusion into the manifold, so that the spray angles don't hit walls when you don't want them to. But that's a problem that most people can deal with.
Eric
You may not
