12-08-2010, 04:25 PM
Originally Posted by Tifosi
A good setup will pull closer to 120% VE with normal asperation. (100% is a shame, not a point of pride)
Beyond that you've gotta get real tricky with cams and such, and/or go to forced induction.
If you could point me in the direction of a standard, road going, common car/engine that produces 120% VE, then I'm all eyes.
12-08-2010, 04:30 PM
1966-2013
Cam overlap alone will produce higher than 100% VE as the wave rushes out the exhaust, then as the exhaust closes, the follow on intake air that is still moving at high velocity stuffs the chamber with X amount more volume than that of the cylinder alone.
EDIT:
Max for normally asperated is purported to be 137%, average joe anycar without any work done, around 80%~85%
Formula for calculating VE = 3456 x CFM / CID x RPM
Words to read
Beyond that, you'll have to do your own research.
[i]Darren[/i]
[size=1][b]'84[/b] [b]manufacture[/b] ~ [b]'85[/b] [b]MY Spider Graduate[/b][/size]
[url=http://www.alfabb.com/bb/forums/spider-1966-up/85437-spider-technical-faq-digest.html][color=green][b][i]Spider technical FAQ[/i][/b][/color][/url]
[url=http://www.alfabb.com/bb/forums/members/ghnl.html][color=darkblue][size=1][b]ghnl's[/size][/b][/color][/url] [url=http://www.hiperformancestore.com/Ljetspider.htm][color=red][size=1][i][b]'82~'89/Series 3 Spider L~jet diagnostic page[/color][/url][/b][/i]
[color=black][i]as hosted by[/i][/color]
[url=http://www.alfabb.com/bb/forums/members/greg-gordon.html][color=darkblue][b]Greg Gordon's[/color][/url] [url=http://www.hiperformancestore.com/][color=red][i]HI Performance Store[/color][/url][/b][/i][/size] [size=1][b][i]&[/i][/b][/size] [url=http://www.okinjectors.com/][color=red][size=1][b][i]OK Injectors[/i][/b][/size][/color][/url]
12-08-2010, 04:34 PM
And how is having that much overlap going to help a road car that doesn't have variable valve timing perform at low engine speeds?
12-08-2010, 05:02 PM
1966-2013
How do you know how much overlap, or lift, or duration is or isn't needed to exceed 100%?
An hour ago you didn't even know you could go beyond 100% with normal asperation.
[i]Darren[/i]
12-08-2010, 05:14 PM
Hang on a second!!!!!
1st of all, I never said an engine couldn't go over 100% VE I sighted a real world example of a standard, common car that achieved 100% VE at sane engine speed (3000rpm) using manifold runner length.
I have read of Jaguar RACE engines that achieved 120% VE, but the relevance of a race engine to a road engine is very little!
And you still haven't named names of a STANDARD, COMMON, PRODUCTION CAR that has achieved 120% VE at sane, typical road car use by Joe Bloggs, engine speed!
And make it a 2 valve per cylinder, non variable valve timing 1 too!
12-08-2010, 05:23 PM
1966-2013
Not my job to research that, especially as it's almost never published and I'm not interested in punching numbers all night long into a calculator to find them just to satisfy your curiosity.
[i]Darren[/i]
12-08-2010, 05:26 PM
That didn't stop you from making claims tho............
12-08-2010, 05:35 PM
1966-2013
that didn't stop you from making claims tho...
[i]Darren[/i]
12-08-2010, 05:48 PM
Jeff 85gtv6 your on the same track as I am,get the velocity stacks higher inside the plenum and away from the walls,also mount the T-body dead center and tapper the ends to create more air velocity to the end runners. the total volume is around 4 lts. stock was 3 .
Again the started as an experiment, nothing ventured nothing gained and to try to cure the uneven burn on my spark plugs.A few calculations and some research and so far its done what I wanted it to.
The fuel reg is a Aeromotive running at 42 psi
Brad
12-08-2010, 06:01 PM
As far as smog go's I think we have it way easyer in Washington, they don't look under the car or in the engine bay and one more year and 87 cars won't have to go though again! I'm still tunning to pass,we'll see.
12-09-2010, 05:59 AM
Originally Posted by Alfar7
Had a long talk with Brad. Seems he`s had a while developing the motor he got from JJ. It was not what was represented by JJ and only made 159HP.  (hmmm Stock?) Brad noted that you never see Dyno data from JJ. Wonder why
dick, you cockbag, Brad never bought a built engine of ANY kind from me! You don't know what you are talking about! He bought a rebuildable core. In fact, he bought a separate set of STOCK-STOCK 3.0 12v heads and a separate STOCK-STOCK sub-assembly from me (to be exact) and I would appreciate it if Brad would please come on here and verify that! Stop spreading lies and misrepresenting the facts dick, you look like an idiot!
Brad merely bought the old standard 80-90K mile 12v Milano Verde 3.0 V6 core out of my black car from me when I installed the 24v in it... Brad was responsible for the rebuild and his own modifications to that core.
As far as dyno-sheets; I have video up on You Tube - on the dyno - panning from the car to the dyno screen, so my numbers are well-documented dick! The red 12:1 compression 3.7 litre 24v n.a. car (it was in a charcoal primer in the videos at the time), was well-documented at 318 and 328 horsepower at the wheels with two different cam-settings (Glenwood cams - not dick jameson bull**** cams!)
The black 3.0 litre n.a 10.0:1 compression 24v Verde has 220 horsepower at the wheels - again - documented on the same dyno as Brad's car in fact!
Get a clue dick and stop lying and telling people that they can have "...275 to 300 horsepower from a 12v with stock components and your cams..."
Full-Race 3.7 Litre 24v Milano 6-Speed Getrag; Restored Street/Track 3.0 Litre 24v Milano Verde; 3.7 Litre 24v Turbo Project!
12-09-2010, 02:36 PM
Whilst the insults flying between JJ and Richard are very amusing, it is also sad that two people who do great work pushing the boundaries of what is possible with our beloved V6s, are behaving like 15 year old school girls. Come on guys, take a couple of deep breaths and get on with your good work and continue giving us the benefit of your knowledge and experience. We don't want to lose either of you.
2008 159 TI Sportwagon 2.4 JTDM (Stromboli Grey)
1990 75 3 litre Potenziata (black)
1990 75 3 litre Potenziata (grey, sadly deceased due to fire).
1988 75 3 litre (red).
1981 GTV 2 litre (red), daughter's daily driver, now for sale.
2000 156 2 litre Twin Spark, ( Cosmos Blu metallic), daughter's new daily driver.
12-09-2010, 03:13 PM
Richard Jemison
Poor JJ
Here is a 3.0 12 V with my cams. Check the dyno...Post # 24 and not from me...on a 10.5 to one motor with miss=timed cams.
http://www.alfabb.com/bb/forums/othe...ld-thread.html
Keep trying JJ you can learn...
Rj
Richard Jemison
RJR Racing
http://scuderiagiallo.com
01-15-2011, 01:54 PM
Nice plenum! Looks like design was essentially 2-piece (floor w/bell housings and roof). Brad, do you think the fibre-glass resin will hold up in time to the heat and petrolium gases? Very nice indeed. I wonder if you could have achieved similar results by sending the stock one off to Extrude-hone?
What we need is someone to design a variable runner intake to help with low-end torque.
Worked quite well for Volvo.
and Volkswagon.
01-15-2011, 03:55 PM
Ford Australia used their dual length (short/long) inlet runners on both the old SOHC 12 valve and the continuously variable valve timing DOHC 24 valve engines.
However, the current incarnation of that engine did away with the cast aluminium dual length manifold and replaced it with a molded plastic example that uses 2 separate plenum chambers, 1 for the front 3 cylinders and 1 for the rear 3. Between the 2 plenum chambers is a butterfly valve that opens at some stage to join the 2 chambers together.
Maybe they rely even more on the VVT (rumor had it that the earlier use of the VVT was very simplistic in its tuning by Ford despite all the capacity of the Ford ECU to run very elaborate, individual mapping of both camshafts) to achieve the typical 4 litre engine low RPM torque.
Toyota also used dual plenum chambers that were linked at some stage during engine operation. They were used on both inline and V6 engines.
On a V6 engine, dual separate plenum chambers that are linked together at some stage, are much easier to implement for a backyarder than dual length runners. Whether dual chambers is as effective at broadening the torque curve as the dual length runners is harder to predict without accurate testing of the same engine with both designs.
