Hi,
I've just registered. I'm french, sorry for my poor english.
I've been reading the suspension threads for the last 2 monthes but never been looking in this chapter. And I was wrong.
Where are you with the dual VVT system ?
I've been thinking about a dual VVT system for last 2 years. I've been waiting to have all the parts I need to build a compressed (Eaton) 2L TS engine. Now I have all the parts but probably won't start the work before 2007 (still a Mini 1000 and the 75TS suspension to build).
Two years ago I added a camshaft intake angular position sensor on my 75TS because I needed it for another project.
I've read lots of papers about modern VVT and their control
I tried to control the VVT position in a continious way by finely positioning the original VVT control 'finger' (which is pushed by the coil), but failed. The system has a very binary operation and it stucks in one or another position. The oil valve should be modified at least by driling several smaller holes at different positions. Modern VVT systems have better oil valve designs which allow more precise control (which is still very dependent on the oil pressure and temperature).
However I believe there is a cheaper and simpler solution. I believe it's possible to restrict the cam angular modification by inserting shims inside the VVT device. Alfa made 30 degree shift on all 1.6/1.8 and 2.0TS engines (I have 4 devices from all these engines, they are compatible). One of both positions is only usable at idle or at very light loads, because the IVC is 90 degrees.
With a 15 degrees shift it would become possible to use both positions at higher loads, for example a 45 and 60 degrees IVC.
A dual VVT system creates new problems as the OFF VVT position is not good for the exhaust side, the VVT should be switched ON it during idle. That could be a problem during the startup.
Another problem comes from the twin spark system, as on TS engines one of distributors is on the exhaust camshaft.
And I believe that even original cams are too wide for a dual system, the cams should be nearer but probably with sharper ramps. Yours seem to be rather 'race' typed.
