#136 (permalink)
Old 08-26-2008, 11:43 AM
Biba69 Biba69 is offline
Gosh buzzed, it wouldn' be any fun if something doesn't go BANG! Yes of course kidding. Without going back over all of the replies/comments, do you by any chance have access to an engine test stand? I would think being able to run it before installing might well save a lot of time. On the other hand, I can also see where it could also be easier to install the engine, then build the components around it - especially the plumbing.
A shame picking up and moving has had to somewhat get in the way of your working on this project. Again kidding. I have no idea how someone could concentrate on both at the same time.
Biba
  #137 (permalink)
Old 08-26-2008, 02:40 PM
gtv27:
That is indeed a WW2 era picture. It's the type of system used in the P47 Thunderbolt.
Buzzed:
You are correct in saying that aircraft are very different from cars. The single biggest difference here is that the engine in the diagram shown is designed to run at a constant RPM. However power varies all over the map because of the variable pitch (constant speed) propeller. So it does see a wide range of power. It also sees a HUGE range of boost. At sea level it only needs about 8psi to get its 2000+hp. At the aircraft climbs the turbo boost increases as high as about 50psi in order to maintain 2000hp.
So this thing actually sees a much wider range of operating conditions than any car, with the exception of RPM.
Greg
  #138 (permalink)
Old 08-27-2008, 12:47 AM
Duk Duk is offline
Good to see your project moving along.
I believe you're on the right track with your turbo requirements.
I'd be looking at the Garrett GT30's or maybe 35's for what you're after. Deffinately be thinking .86 A/R turbine housing, 1.06 A/R is probably a bit big and 0.64 A/R probably going to choke your flow. Exhaust manifold design will be critical to reduce pumping loss's (back pressure), and so I highly reccomend that you look at the way othe high HP turbo manifolds are made by the likes of HKS and TRUST. Log manifolds work (poorly ), but they will compromise your whole engine's potential.
A mate of mine has a 500 hp Garrett GT30 turbo (can't remember the turbine A/R), on a 2.6ltr Sigma (factory Sigma turbo), injected (reprogrammed TP Magna computer ), intercooled, ported head, excessively large cam and a very low 7(ish):1 compression ratio. The way that thing gets onto boost (read: very quickly) and pulls to it's rev limmiter (7500rpm) is impressive to say the least. Although the car hasn't reached it's full potential (it's getting a programmable computer soon), an Alfa with that kind of torque curve would be some serious fun, but also easy to drive because of the linear/progressive nature of the engine.
Alfa 75 Potenziata
Supercharged AW11 MR2 (soon to be twincharged)
RB20DET S13 Silvia
  #139 (permalink)
Old 08-28-2008, 07:19 AM
buzzed buzzed is offline
Biba69 - I don't have access to an engine dyno but have seriously considered building one in the new shed I am building...May have to settle for setup in the car for now though, time wise, at least for engine 1.
Greg:
Ah yes, I see what you mean, so does mass flow at the engine inlet vary a lot also? Mmmm 2000hp...must...have.....enter 'best Homer drool impersonation'
Duk:
Yeah I had an rx7 s3 13b with GT3540 turbo and ported. On 16 psi that thing was good for 245rwkw's. The rear end on that was a .86, with the way a 13b works its equivalent to a 2.6liter motor. With the supercharger, I think I may be able to run a 1.06, without it, I would just run a 0.86 for sure. The supercharger should give me ample mass flow to spool the 1.06 nicely....I think...maybe :-)
  #140 (permalink)
Old 08-28-2008, 08:42 AM
I wouldn't worry about turbo spool up time or boost threshold on this engine, the supercharger will take care of those issues for you. I would make sure the turbo can flow a lot of air, at least enough for the target horsepower and a lot more than the supercharger.
Buzzed, I didn't want to make this into an aviation discussion, but since you asked, and it is your thread here goes.
The mass air flow in the compound system shown in the G.E. diagram I posted actually stays about the same when at full throttle, throughout the engines huge operating range. It uses something normally called a "density controller". This device increases boost to maintain a certain density or mass of air entering the engine in order to keep horsepower the same. In other words, full throttle at sea level will result in about 8psi and 2000 horsepower (it's a really big engine, turning really low rpm). As the aircraft climbs atmospheric air pressure and thus density decrease so the turbo feeds in more and more boost to keep the air density, and thus horsepower constant. Thus at 40,000 feet it has something like 50 pounds of boost and still puts out the full 2000 horsepower. The density controlling is done entirely by varying the turbocharger's speed. The supercharger runs at a constant speed.
These same "density controller" systems are still in use today. Most, if not all Lycoming turbocharged aircraft engines are set up this way.
Greg
  #141 (permalink)
Old 08-28-2008, 06:42 PM
Duk Duk is offline
I do believe that correct turbo sellection is still to be considered, even with a twincharger set up.
On my twincharger set up in my Toyota MR2, there is still a noticable boost threshold for the turbo (Mitsubishi TD06 with a farely large turbine housing).
However, I do believe that the turbo boost threshold would be lowered with higher boost from the supercharger and a better exhaust manifold (log type made purely for conveniance due to location in the engine compartment and a new tubular type is planned).
Achieving the most seemless torque curve would have to be the most brilliant driving pleasure IMO
Buzzed, was your RX7 ever featured in any Australian magazines?
Alfa 75 Potenziata
RB20DET S13 Silvia
  #142 (permalink)
Old 09-01-2008, 07:35 AM
Greg: That make's sense. I think you are adding to the interest of this thread anyway, and my education! I am not too concerned with the spool up time of the engine so much as the transient response of the turbo, as I agree, the supercharger will help cover 'lag'.
Duk: I keep forgetting that you run a twin charge setup already. Is it in series and do you switch the supercharger off or leave it running?
As for my Mazda, it had a 5 page feature in Zoom Killer conversions.
I've done my turbo sizinf numbers based on the following assumption:
2liter engine running 10psig from supercharger equates to a 3.3liter NA motor. So I ran my numbers on a 3.3 liter motor running 15psi from the s/charger. I then chose a turbo based on the toral mass flow of the engine but at only 15psi, since this is the pressure the turbo will need to supply but at the total mass flow.
I've settled on a GT3582R turbo from Garrett. My calculated curve ranps up through the meat of the effificeny range and only drops to 74% efficiency (from 79%) at full load, whilst the midrange will pass back and forth through the peak efficiency island. It has the added bonus of being able to supply the total mass flow at 25psi with ease, which means I can test the setup in turbo and turbo+scharger modes to compare. Extenally gated and with aT3 flange it will suit my application nicely. I will use the 1.06 turbine housing. At 1650 AUD from Horsepower in a box it's a steal...cough. I spotted them for 1299 USD at JNZ but by the time you factor in exchange rates and postage it's not worth the hassle.
Head is back from the machine shop, engine reassembly starts wed next week. I had Turin imports send me new top and bottome timing chains...cheap insurance at around 50 dollars each.
  #143 (permalink)
Old 09-01-2008, 08:40 PM
Duk Duk is offline
My twincharger set up is very simple. Turbo pumps thru the throttlebody and into the supercharger (standard pulleys) and doesn't use any form of SC switch off or bypass (apart from the original Toyota bypass/switch off used to improve economy/keep noise down at light throttle).
The reason I sugested a bypass and a SC switch off in a previous post is because I was a little disapointed with the overal performance of the car and figure it might help a more serious instal like yours.
Having said that, my car still uses the same 2.5" exhaust that was quiet enough for the when the engine was only SC'd and is now uber quiet with the turbo.
I made a poxy log manifold for practicality (popper 1 in the 'to do' basket ).
The inlet air has to go thru much pipe work and many bends to reach the turbo (still using a flap type airflow meter, tho bigger than standard).
The intercooler (modified Pulsar GTiR) in an AW11 MR2 is in the worst place in the whole entire world, especially once a turbo is added and heats up the cooling air even more so.
After reading lots more on the subject, especially stuff suplied by Greg, I too am now subscribing to the KISS principle, and just use a simple blow thru the SC, no bypass or SC switch off.
That was exactly the car I was thinking about when you described it previously . Spooky
PS, I thought your RX was done superbly and I'm realy keen to see your twincharged Alfa (with many photo's ).
Alfa 75 Potenziata
RB20DET S13 Silvia
  #144 (permalink)
Old 09-02-2008, 04:18 AM
Glad you liked the Mazda Duk, I loved driving that car. Actually if you want to see a freinds rotor start for the first time about a week ago, go to this link:
he's running all my gear that I amassed for another project that I ended up bailing out of (Mazda 1500 13bt). He's running all the cosmo gear in a s2 rx7. He's done all the work himself, and I mean everything, with just advice from myself and others. He's even fab'd up rack and pinion steering, a point of perfection sorely missing from my conversion. Don't know if you've driven rx7 s3's with recirc ball steering....but they are bad...real bad.
Point noted on photos, they'll be coming shorlty as I will grab some of the newly done head and block as I assemble it with my mate.
  #145 (permalink)
Old 09-02-2008, 04:27 AM
Duk Duk is offline
Drove a s2 with a sloppy 'box (minds out of the gutter, please ()), not the best experience, even tho it was a stock 12a with extractors .
Alfa 75 Potenziata
RB20DET S13 Silvia
  #146 (permalink)
Old 10-05-2008, 11:58 AM
buzzed, you're busted. Super1600 posted a photo of your Alfetta he recently took and it looks like you're just playing around when you should be back with your nose to the grindstone, if not the lathe working on on your 'little project'.
You owe it to your international audience. You can alway play later after you've finished your homework.
Biba
  #147 (permalink)
Old 10-06-2008, 04:43 PM
PSk PSk is offline
What has all these comments got to do with an Alfa Romeo?
An Alfa GTV's steering box system is as good as a rack and pinion, so please just because Toyota/Mazda/whoever cannot design a decent steering box does not mean Alfa can't. If you wanted to change the steering ratio, well then I could understand thinking about the conversion (but you can change the stub axle arms), otherwise wasting your time.
  #148 (permalink)
Old 10-06-2008, 05:32 PM
batman batman is offline
The alfa steering box and all those joints isn't anywhere as good as a proper well designed rack and pinion steering
I fitted a Triumph Dolomite Sprint steering rack to my race Alfa Sprint GTA,Its just perfect!
  #149 (permalink)
Old 10-06-2008, 07:46 PM
PSk PSk is offline
Personally I've never driven a car with better steering than my GTV. There is NO play at all and it is well weighted.
Now ofcourse a rack is a better concept, but an Alfa steering box should not be compared to a piece of cr@p that obviously was not maintained properly.
Racks can develop play too ... so anybody that believes a GTV steering has play in it is wrong and needs to learn to maintain their car.
Lets ensure perceptions are accurate. Next we will have people not buying Alfas because they read somewhere that the steering is sub-pay, when infact it is one of their best points.
Best
