Alfa Engine Specs & Horsepower - Alfa Romeo Bulletin Board & Forums
post #1 of 2 (permalink) Old 08-22-2006, 07:43 PM Thread Starter
Charlie DiMarco's Avatar
Hi Everybody,
I put together a list of Alfa engines with there specs. from this link.
http://www.conceptcarz.com/vehicleLi...lVehicles.aspx
This info might be useful for those who are interested in doing an engine swap. I would also like to hear from Greg Gordon (supercharged V6 engine builder and now working on a supercharged 4) Jungle Justice and his available selection of South African built Alfa V6 engines. And Martin De Campo lets hear about your Greg Armstrong built special Callaway engine. And of course anyone else who has built or purchased a special Alfa engine.
2006 Alfa Romeo 159
Engine Configuration V
Cylinders 6
Aspiration/Induction Normal
Displacement 3.20 L | 195.3 cu in. | 3201 cc.
Valves 24 valves.
4 valves per cylinder.
Valvetrain DOHC
Horsepower 260.00 BHP (191.4 KW)
HP / Liter 81.3 BHP / Liter
2004 Alfa Romeo 156 GTA
Cylinders 6
Valves 24 valves.
Valvetrain DOHC
Horsepower 250.00 BHP (184 KW) @ 6200.00 RPM
Torque 300.00 NM (221.2 Ft-Lbs) @ 4800.00 RPM
HP to Weight Ratio 12.4 LB / HP
HP / Liter 78.1 BHP / Liter
Bore 3.66 in | 93 mm.
Stroke 3.07 in | 78 mm.
Compression Ratio 10.50:1
1995 Alfa Romeo 164 LS
Cylinders 6
Displacement 2959.00 cc | 180.6 cu in. | 3 L.
Valves 24 valves.
Valvetrain DOHC
Horsepower 210.00 BHP (154.6 KW) @ 6300.00 RPM
Torque 198.00 Ft-Lbs (268.5 NM) @ 5000.00 RPM
HP to Weight Ratio 16.6 LB / HP (Vehicles with similar ratio)
HP / Liter 70.0 BHP / Liter
Bore 93.00 mm | 3.7 in.
Stroke 72.60 mm | 2.9 in.
1991 Alfa Romeo 164 L
Cylinders 6
Valvetrain OHC
Horsepower 184.00 BHP (135.4 KW) @ 5800.00 RPM
Torque 185.00 Ft-Lbs (250.9 NM) @ 4400.00 RPM
HP to Weight Ratio 18.7 LB / HP (Vehicles with similar ratio)
HP / Liter 61.3 BHP / Liter
Compression Ratio 9.5:1
1991 Alfa Romeo SZ
Cylinders 6
Displacement 3.00 L | 183.1 cu in. | 3001 cc.
Valvetrain OHC
Horsepower 207.00 BHP (152.4 KW) @ 5900.00 RPM
HP to Weight Ratio 15.9 LB / HP (Vehicles with similar ratio)
HP / Liter 69.0 BHP / Liter
Stroke 72.70 mm | 2.9 in.
Compression Ratio 10.0:1
1990 Alfa Romeo SZ
Cylinders 6
Valvetrain SOHC
Horsepower 210.00 HP (154.6 KW) @ 5900.00 RPM
Torque 180.00 Ft-Lbs (244.1 NM) @ 3000.00 RPM
HP to Weight Ratio 13.2 LB / HP
Bore 3.46 in | 87.9 mm.
Stroke 2.68 in | 68.1 mm.
1989 Alfa Romeo Milano Verde
Cylinders 6
Valvetrain SOHC
Horsepower 183.00 BHP (134.7 KW) @ 5800.00 RPM
Torque 181.00 Ft-Lbs (245.4 NM) @ 3000.00 RPM
HP / Liter 61.0 BHP / Liter
Stroke 2.86 in | 72.6 mm.
Main Bearings 4
Fuel Type Gasoline - Petrol
Fuel Feed Port fuel injection
1986 Alfa Romeo GTV-6
Cylinders 6
Displacement 2492.00 cc | 152.1 cu in. | 2.5 L.
Valvetrain SOHC
Horsepower 155.00 BHP (114.1 KW) @ 5500.00 RPM
Torque 150.00 Ft-Lbs (203.4 NM) @ 3200.00 RPM
HP to Weight Ratio 18.2 LB / HP (Vehicles with similar ratio)
HP / Liter 62.0 BHP / Liter
Stroke 2.69 in | 68.3 mm.
Compression Ratio 9.0:1
2001 Alfa Romeo 147
Engine Configuration I
Cylinders 4
Displacement 2.00 L | 122 cu in. | 1999.6 cc.
Valves 16 valves.
Valvetrain DOHC
Horsepower 150.00 HP (110.4 KW) @ 6300.00 RPM
Torque 130.00 Ft-Lbs (176.3 NM) @ 3800.00 RPM
HP to Weight Ratio 18.5 LB / HP (Vehicles with similar ratio)
HP / Liter 75.0 BHP / Liter
1992 Alfa Romeo Spider Veloce
Cylinders 4
Displacement 120.00 CU IN. | 1966.8 cc. | 2 L.
Valvetrain DOHC
Horsepower 120.00 BHP (88.3 KW) @ 5800.00 RPM
Torque 120.00 Ft-Lbs (162.7 NM) @ 2700.00 RPM
HP to Weight Ratio 21.2 LB / HP (Vehicles with similar ratio)
HP / Liter 60.0 BHP / Liter
Bore 3.31 in | 84.1 mm.
Stroke 3.48 in | 88.4 mm.
Fuel Feed Bosch Motronic Injection
1984 Alfa Romeo Spider Veloce
Cylinders 4
Displacement 1962.00 cc | 119.7 cu in. | 2 L.
Valvetrain DOHC
Horsepower 115.00 BHP (84.6 KW) @ 5500.00 RPM
Torque 120.00 Ft-Lbs (162.7 NM) @ 2780.00 RPM
HP to Weight Ratio 22.1 LB / HP (Vehicles with similar ratio)
HP / Liter 57.5 BHP / Liter
Fuel Feed Bosch L-Jetronic Injection
1971 Alfa Romeo GTV Veloce 1750
Cylinders 4
Displacement 108.50 CU IN. | 1778.3 cc. | 1.8 L.
Valvetrain DOHC
Horsepower 135.00 BHP (99.4 KW) @ 5500.00 RPM
Torque 137.00 Ft-Lbs (185.8 NM) @ 2900.00 RPM
HP to Weight Ratio 16.1 LB / HP (Vehicles with similar ratio)
Bore 3.15 in | 80 mm.
Fuel Feed Spica Injection
1967 Alfa Romeo Duetto
Engine Configuration S
Cylinders 4
Displacement 95.8 cu in. | 1570 cc. | 1.6 L
Valves 8 valves.
2 valves per cylinder.
Valvetrain DOHC
Horsepower 109.00 BHP (81.3 KW) @ 6000.00 RPM
Torque 105 Ft-Lbs (142.0 Nm) @2800 RPM
HP to Weight Ratio 19.0 LB / HP
HP / Liter 69.43 BHP / Liter
Bore 3.07 in | 78 mm
Stroke 3.23 in | 82 mm
Compression Ratio 9.00:1
Fuel Feed 2 Weber Carbueretors engine Inline-4
1965 Alfa Romeo Giulia Sprint GTA
Cylinders 4
Displacement 1570.00 cc | 95.8 cu in. | 1.6 L.
Valves 8 valves.
Valvetrain DOHC
Horsepower 115.00 BHP (84.6 KW) @ 6000.00 RPM
Torque 105.00 Ft-Lbs (142.4 NM) @ 3000.00 RPM
HP to Weight Ratio 14.2 LB / HP (Vehicles with similar ratio)
HP / Liter 71.9 BHP / Liter
Bore 3.07 in | 78 mm.
Stroke 3.23 in | 82 mm.
Compression Ratio 9.70:1
Main Bearings 5
Keep the Revs Up,
Charlie
www.serpentautosport.com
Charlie DiMarco is offline
post #2 of 2 (permalink) Old 08-24-2006, 05:25 PM
Hi Charlie,
I will have to base everything on REAR WHEEL HORSEPOWER as I don't have the ability to dyno these things any other way. However I have the stock rear wheel horsepower numbers so a before and after percentage increase can be seen.
All testing has been done on engines that have no performance modifications other that the supercharger. All used the factory's L-Jetronic fuel injection and no intercooler, and of course pump gas. I will only post results on cars I have personally tested.
1. Stock 1985 2.5 GTV6 125 RWHP
1a. Supercharged 1985 GTV6 182 RWHP at 7+ pounds of boost.
2. Stock 1988 3.0 Milano Verde 148 RWHP
2a. Supercharged 1988 3.0 Verde 205 RWHP with 5 pounds of boost
2b. Supercharged 1988 3.0 Verde 228 RWHP with 7+ pounds of boost
Greg Gordon is offline
