07-16-2006, 01:47 AM
Twin Spark Project
07-28-2006, 03:53 AM
Tell us more about your dissy! Is it an adapted from a Nissan?
I'm just finnishing a Twinspark to go in a 105 and looking at the ignition options. I like the idea of mapable ignition, but I also like the idea of it looking sort of period with a distributor? How have you set the advance curve?
Whats the approximate cost?
Cheers Nick
Nick
71 1750 x2
67 GTV
07-28-2006, 04:28 AM
75/Milano manuals for all
G'Day Nick,
I can't answer for Hugh (I think it's Hugh) but if you're keeping the EFI then it's a Nissan twinspark cap and rotor grafted to an empty bosch ( or Marelli ) dizzy (no points etc).
If you're ditching the EFI it get's more complicated.
Both can be bought from Jim Steck http://www.autocomponenti.com/perfor...re_distributor
07-28-2006, 05:42 AM
Originally Posted by Craig
G'Day Nick,
Thanks Craig,
Yes, the orginal EFI is long gone! I'm going with 45 Dellortos, ported head with higher CR & reground cams. Hopefully 160ish HP with good mid range power.
I had planed to put it in my step front to make a GTA rep, but I came aross a very straight 1750 shell. So I think that it will live in the 1750 body until i find some step front panels.
Do you know if you can run a mappable system through a distributor (just to distribute the spark)? I like the idea of keeping it sort of orginal looking?
The only electronic systems that I have seen look like an octopus on the fire wall!
Out of interest on EFI systems what the square block the the HT leads come out called? Do they perform the same function as a coil? Can you get individual units or do they only come as blocks of four?
Sorry if this is a supid question, but I just was wondering if you could put them in the body of GTA style distributor to provide the look, but retain the functionality?
Cheers Nick
Nick
71 1750 x2
67 GTV
07-28-2006, 12:39 PM
"Do you know if you can run a mappable system through a distributor"
yes that is very common you will need a triggerwheel some where ether in the dizzy or a lot better on the crank. the dizzy has a lot of shake so you get spark scatter. if you can trigger on the crank the timming will be rock stable. the problem with runing a single coil can be the charge time at max RPM if you run wasted coils you get 2x the time to charge. etc so as long as the dwel time for that one coil will fit for the max RPM you will run it will work fine.
1987 black Milano Verde
1972 White spider 2000 Veloce
07-28-2006, 01:11 PM
Cheers Nick
They are called coil packs. You can get them individually, for coil-on-plug applications, or packs of 2, 4, or 6. The two packs are what Electromotive used on their TECII's. 4 packs are what we commonly used for 4 and 8 cyl products, and 6's for 6's.
If you could use a single 4 pack, there's no reason why you could not mount it to sit in the exact same position as the distributor- having a hole that large should be able to hold up a pretty heavy thing. Pait it red, and only the very observant would notice that it's not a real distributor.
One interesting solution for the distributor style ignition- use a Mega Squirt... no need to use the inectors- you can just use the spark output that can be set up to run a distributor. Not sure which one off the top of my head, but you can...
Eric
07-29-2006, 05:15 AM
Eric
Thanks for the info Eric,
From reading the other threads mega squirt looks interesting, but as you can see I don't know heap about electronic sytems! What would be required to use it in a twinspark application? Has anyone actually done it successfullyin a twinspark?
Can you buy the components made up?
Cheers Nick
Nick
71 1750 x2
67 GTV
08-01-2006, 03:23 PM
By the way, there is a repacement distributer called the 123\GB-4-R-V which replaces most 4 cyl Lucas distributers. Marelli drives and shaft sizes appear to be the same as this unit which is no surprise as Lucas and Marelli were interchangeable on the earlier cars. But what makes this distributer interesting, is that it has 16 different advance curves. In effect it is mappable. No connection to the Company..find them on 123ignition.com.
Stuart
08-02-2006, 05:21 AM
Interesting, I wonder if I could adapt the top to fit a Nissan twinspark cap? Any idea if the advance curve would suit a twin spark application? $550 Australian is lots cheaper than a fully programable ignition?
Nick
Nick
71 1750 x2
67 GTV
08-02-2006, 10:49 AM
Don't know. Give 'em a e-mail find out. May be just the thing for you! Best of luck
Stuart
08-03-2006, 06:44 AM
Cheers Nick
Nick
In theory, yes, it will work.
The problem for you is that getting these parts way down in the South Pacific will be a major PITA. I'm not sure the exact aftermarket parts, and I'll get back with you from a buddy of mine who works at an auto parts place locally.
But, start with an MS + EDIS- that's the Ford version of the distributorless ignition with the megasquirt.
For the EDIS hardware, use a module from a 2.3l Ranger TS Pick up truck. In the late 80's/ early 90's, we actually made a twin plug Ranger, yes- and it happened to be one of the first applications of the EDIS system inside of Ford.
You'd need the coil pack pair, the small EDIS module, the crank sensor, and the tone ring off the crank.
Follow the directions on how to install the MS+EDIS and you'd be all set.
However, to make it look like you want it to would be more difficult than the basic single plug, as you'd have to fit 2 coil packs underneath the intake. I'm not saying it can't be done, but it's just not as easy.
IMHO, I think you already have a workable solution....
Eric
08-03-2006, 07:10 AM
Hi,
i´m currently building a TS engine with an EMS Stinger ECU ( http://www.enginemanagementsystem.com/ ), and i just use the engine´s original 60-2 crank wheel with the standard sensor. My setup is 4 double-coils in a distributorless, wasted spark setup (cylinders 1+3 and 2+4 always fire the sparks at the same time).
That should work very fine, and this kind of setup should also be possible with other engine management systems as e.g. megasquirt.
Thomas
08-03-2006, 12:17 PM
Originally Posted by nda9h
Hi,
Thomas
That system is the same configuration as the one we use so successfully:- http://www.alfaholics.com/racing_and...nt_289_138.php
[COLOR=Blue][URL]www.alfaholics.com[/URL][/COLOR]
1966 2.0 Sprint GT race car, 1967 T/S GTA Replica, 1965 FIA App.K 1600 GTA, 1965 1600 GTA Stradale RHD, 1965 1600 GTA Stradale LHD, 1966 1600 Giulia GTC, 1991 S4 Spider, 1967 1600 Duetto, 1999 2.0 916GTV (soon to be sold!) and now replaced with 2002 3.0 V6 24v 916 GTV
08-07-2006, 07:17 AM
Here's some info I got in an e-mail from a friend of mine who is a parts person:
Good start for parts.
Eric
11-06-2009, 02:29 PM
seems everybody has done it but no one tells about it.
How the devil you fit the rotor and cap , what you do with the mechanical advance? what kind of distributor u use ? i got a magneti marelli early one with mech advance and there are many issues , the mechanical advance unit makes the nissan cap sit about 6cm from the dist base
