Old 02-26-2006, 11:28 AM
Alfapwr's Avatar
Alfapwr Alfapwr is offline
TS into Super
Hi Y'all,
Can a TS be made to work with a 1600 trans with mechanical clutch ? I know 1750's bolt right up and regular 2000's need a special flywheel and the old ring gear. I'm just wondering how a TS would work ( or even FIT ) in a Giulia Super.
Dan
Old 02-26-2006, 01:33 PM
dan farmer dan farmer is offline
Here's a piece of the puzzle: an adapter to make your clutch cable actuate the later clutches from hydraulic cars.
http://www.centerlinealfa.com/produc.../pages/p18.pdf
Here's an article about its use, as printed in the January club mag from ARA(I've learned a lot from belonging to both ARA and AROC):
http://www.alfaromeoassociation.org/cams/CAMSJan06.pdf
-df
Old 02-27-2006, 06:16 PM
Alfapwr's Avatar
Great Articles !!!
So other than needing this adapter is putting a TS in any different than in a later 115 car ?
Dan
Old 03-02-2006, 05:41 AM
sparkyshep sparkyshep is offline
ts in 1600 super
hi I have a ts with a 1600cc mech clutch assy I was going to convert to hydralic clutch but it did seem to be a big pain I had a ally lightweight flywheel for a 1600 engine drilled for a ts mountings supplyed by okp in germany there quality is very good and it all works fine engine idles ok as well good luck if you go ahead i am nearly finnished had it all running on weber 40,s but upgrading to 45 dellortos with 36 chokes for abit more power at the top end
