#91 (permalink)
Old 12-07-2006, 08:25 AM
Keven's Avatar
Keven Keven is offline
Gents,
Here's their contact info:
L&M Stripping
14232 Aetna St
Van Nuys, CA 91401
phone: 818-983-1200
Ask for Jim, he is very friendly and helpful. He faxed me a quote
for my job. I'm sure the price depends on the car. To dip my GTV,
hood, trunk, and doors is around $1400. Not sure if this is a good
deal, but where else can I go? I looked into sand blasting, and got
quote's for around $1000, and this did not include doing the underside.
I heard that sandblasting can be quite damaging to the metal if not done
correctly, and uhh the guys I got quotes from did not inspire confidence
that they would take the appropriate care.
Jim told me that they use a solution of muriatic acid, which is essentially
pool cleaner. Not sure in what concentration, but according to Jim, it
will not harm the metal at all. Also they dip the car in a bath of neutralizer
to stop the acid's process. The reason I didn't worry to much about the
process is that Anthony had posted that they had done several cars
using this method, with no problems.
As far as getting the car into the U-Haul, let's just say that it was a real
biotch!! I think that the whole thing weighs around 500 pounds, and
my brother in law and I lifted it into the truck one end at a time. You really
need three people for this, if you don't want to torque a nut
1978 Spider sold in 1996
  #92 (permalink)
Old 12-07-2006, 10:14 AM
olycarguy olycarguy is offline
Thanks for the info. One thing I would ask is.....MORE photo's of your project!! I worked for honda some years ago and was always awed by their power to cc ratio. You'll have a real hotrod to gun down those unsuspecting 5.0's! I did a rotary converson into a 67 gt jr back in the mid-90's and was amazed at how easy the project went together (I converted it back to alfa power a few years later when vintage racing took off). It was very fast and pulled hard to 8500rpm. Good luck and keep us posted. T.H.
  #93 (permalink)
Old 12-07-2006, 09:02 PM
benjoys02's Avatar
benjoys02 benjoys02 is offline
rotary gtv
olycarguy, i sent you a pm.
benji
  #94 (permalink)
Old 12-08-2006, 05:58 AM
MALDI's Avatar
MALDI MALDI is offline
I had never heard of muriatic acid. It turns out to be hydrochloric acid (HCl).
http://en.wikipedia.org/wiki/Hydrochloric_acid
  #95 (permalink)
Old 12-08-2006, 09:51 AM
vintage prep's Avatar
vintage prep vintage prep is offline
Bead or walnut blasting is another way to go. Naturally these methods would not clean the inside boxed in sections.
For those in Orange County Ca. there is Strip Clean on 1st st. in Santa Ana.
One thing dipping does is reduce the metal thickness. I had the Felix car stripped during the build process, and when I sold the car, the buyer insisted on weighing it before paying what he considered "a kings ransom". He brought his calibrated scales and we found that Felix (67 GTV) weighed 1570 lbs with half a tank of fuel!! We were all very suprised, and needless to say, the full ransom in cash was immediately tendered.
I found that some of the Phosphate Neutralizer was trapped in the rockers and elsewhere even after a couple of weeks, and was quite slow to dry. I used a torch to carefully heat up the boxed in areas and the phosphate would bubble up and ooze out.
I was wrong once before,
Paul Van Der Linden
Currently: 70 Giulia Ti 2.0L
Formerly:
(1) 58 spider
(2) 67 duetto's
(4) 67 super's
(2) 67 gtv's
(1) 70 gtam
(2) 74 gtv's
(1) 78 spider
(1) 82 spider
  #96 (permalink)
Old 12-08-2006, 10:28 AM
turbolarespider turbolarespider is offline
Originally Posted by UngaWunga View Post
How will you prevent rust on the inside, between panels, where you can't reach with a spray gun?
Interesting process. Suprised they're still allowed to operate in CA, since CA made it almost impossible for that surfboard core manufacturer to operate due to emmision laws. Drove them out of business last year, and surfboard prices went through the roof.
I think chroming companies are facing the same close scrutany out in CA.
I'd be willing to bet that CARB is well aware of this shop, and they do a pretty good job at keeping things clean. Especially knowing what kind of other shops they shut down.
What's funny about it- they claim it's "expensive" to put in the equipment. As opposed to being closed for not. That particular board company could have done things to make their shop in compliance, but they insisted not to.
There are some very environmentally sound strippers, chrome'rs, etc. out there- mostly, they are the ones that are still open.
Support those businesses, they help make it possible to keep old cars on the road! (not just for parts, I mean)
Eric
  #97 (permalink)
Old 12-10-2006, 09:31 AM
SFoggy's Avatar
SFoggy SFoggy is offline
paint coverage inside things.
Does anyone know of a vendor to do dipped primer? Ford does that, no? Others? Our GTVs are full of crevices.
  #98 (permalink)
Old 12-10-2006, 11:45 AM
I have yet to hear of anyone that will dip prime a car. It's something that only a manufacturer can do on new (read spotlessly clean) metal. There are dip galvinizers that could do a whole car body in Los Angeles, but I've never heard of anybody going to such lengths.
BTW, I forgot to add on my previous post, "two thumbs up" for Kevin. The amount of fabrication and engineering you have done is amazing. I'm sure every Alfisti here in So Cal is looking forward to seeing your car completed. I hope it will be done in time for next years Dyno Shootout at Magnaflow.
Paul Van Der Linden
Formerly:
(1) 58 spider
(2) 67 duetto's
(4) 67 super's
(2) 67 gtv's
(1) 70 gtam
(2) 74 gtv's
(1) 78 spider
(1) 82 spider
  #99 (permalink)
Old 12-10-2006, 03:32 PM
PSk PSk is offline
And the shell has to be designed for it ... a 105 series Alfa would pool paint, etc.
  #100 (permalink)
Old 12-12-2006, 06:21 PM
Grant's Avatar
Grant Grant is offline
Anyone have more info/pics of that 75 with the SR20 in it? You can PM if you wish.
1984 GTV-6 - 80K miles
  #101 (permalink)
Old 12-13-2006, 02:47 PM
GTV-GR's Avatar
GTV-GR GTV-GR is offline
Kevin i'd definately like to have your car in my garage next to my Gtv, i'd have the car look like **** though on the outside , i'd paint it to match rust and look crap , only reason i'd do this would be just to look at the face of the rivals at the stop light when i would kick the living **** out of them
  #102 (permalink)
Old 01-02-2007, 08:41 AM
Keven's Avatar
Went down to L&M to see the progress of the stripping. Got to meet
Jim in person, and must say he is a really nice and great guy!!
He and his workers have done a really great job on the car, it's
really weird to see the car down to the bare metal, almost looks
like it's fresh off the assembly line, uhhh except for the bondo here
and there. There really is not much damage, or serious structural
rust to speak of. Next step is etching primer.
Here's a few pics for your enjoyment.
  #103 (permalink)
Old 01-02-2007, 08:42 AM
Keven's Avatar
More pics...
  #104 (permalink)
Old 01-18-2007, 08:48 AM
Keven's Avatar
Got the car back form L&M with primer shot on the body and all the panels.
It really came out great, and am very happy with the work that Jim and his
crew did at L&M. Next step is to do the undercoating and then install the
suspension. Here's a few pics...
  #105 (permalink)
Old 01-18-2007, 10:12 AM
silverspider's Avatar
silverspider silverspider is offline
Location: NYC, NY. The Spider resides on Shelter Island, NY.
Kevin: You are evidently from the "if its worth doing, its worth doing right" school. Looks great so far.
1975 Spider (Long gone gateway drug)
1983 Spider (Dead: slowly parted-out on eBay)
1974 Spider (Body restoration only took 14 months , now undergoing wallet evaporating full mechanical rebuild)
