#46 (permalink)
Old 06-19-2006, 08:56 AM
Barryh Barryh is offline
Thanks Kev...Would be a bummer after all your work.
  #47 (permalink)
Old 06-22-2006, 09:14 AM
Max Banks's Avatar
Max Banks Max Banks is offline
Kevin,
Fascinating project, how does the s2000 lump compare for weight?
Have you planned how you are going to sort out the engine cross member yet whilst maintaining adequate ground clearance?
The motor i'm very keen on going a conversion to is a Rover K-series - they weight a mere 79kgs and the VHPD items they are putting in the best Caterhams are 250bhp... if mated to a Caterham 6 speed sequential box I think it would make a hilarious drive!
[COLOR=Blue][URL]www.alfaholics.com[/URL][/COLOR]
1966 2.0 Sprint GT race car, 1967 T/S GTA Replica, 1965 FIA App.K 1600 GTA, 1965 1600 GTA Stradale RHD, 1965 1600 GTA Stradale LHD, 1966 1600 Giulia GTC, 1991 S4 Spider, 1967 1600 Duetto, 1999 2.0 916GTV (soon to be sold!) and now replaced with 2002 3.0 V6 24v 916 GTV
  #48 (permalink)
Old 06-22-2006, 10:05 AM
Keven's Avatar
Keven Keven is offline
Max,
Good question, I have been trying to figure out an economical
way of weighin both engines. Thought of using a strain strip
on the arm of the engine hoist, and lifting each of them the
same way and compare readings. I think the strips glue onto
beams, and one can measure the change in resistance as they
are strained. Not sure where to buy these. Anyone have ideas?
I guess bath scales are out
As far as the clearance, I think if you look a few pages back I posted
a pic with the motor in place. I think that the oil pan is actaully less
vulnerable than the Alfa's, in fact, I dont think I need any guard.
Max, I have been surfing your website, and love your suspension kits.
Especially the lightened spring pans, and small springs!
When I start building the suspension, I will definetely contact you.
The project is moving at a turtles pace, mostly due to work. I have
been cutting small bits and peices to finish the welding of all the cross
members, and new floor pans, and tranny tunnel. I should get some time
this weekend. I'll post more progress then.
1978 Spider sold in 1996
  #49 (permalink)
Old 06-23-2006, 04:27 AM
Max Banks's Avatar
christ... I can't keep up with this thread... go to bed for one night and my post is buried under 3 more pages of chat! Very popular Kevin! Best of luck, drop me an e-mail at my company address at any point you like...!
  #50 (permalink)
Old 06-23-2006, 04:31 AM
Max Banks's Avatar
p.s. I would just weight the negines on a pair of bathroom scales once you have made up a pair of cradles for putting the engine on... unless you have flat patch corner weight scales.
come to think of it, 2000cc Alfa engines weigh about 100 kgs give or take 5kgs, so a bit of Google action will probably come up with the weight of an S-2000 engine without need for manual labour... unless fingering a mouse is classed as manual labour.... ohh did that come out wrong?
  #51 (permalink)
Old 06-27-2006, 05:16 PM
physician physician is offline
Its 386LBS.. thats without the tranny
heavier than the alfa engine .. but twice the power...
  #52 (permalink)
Old 06-28-2006, 02:31 PM
Mikes4C1300's Avatar
Mikes4C1300 Mikes4C1300 is offline
A couple of threads on s2ki.com put the F20C engine (sans transmission) at 326 pounds. 2.2L shouldn't be significantly different. Couldn't find anything on trans weight.
Mike Hollinger
Atlanta
'60 Giulietta spider, '67 GTV, '02 S2000
  #53 (permalink)
Old 06-29-2006, 02:58 PM
Max Banks's Avatar
can't be 386 lbs surely... thats over 170 kgs... does it have an iron block or something? If so i'm gonna have to put a serious thinking cap on for spring rates for you Keven!
  #54 (permalink)
Old 06-29-2006, 11:45 PM
slyalfa slyalfa is offline
weight
engine pounds ref. comments
Lexus V8 32V 1UZFE 4L 390
Toyota V8 32V 2UZFE 4.7L 475 Iron block in Toyota trucks
Alfa Romeo SOHC V6 375 (2)
Alfa Romeo 415/85T 279 (31) F1 four, '87 season
Alfa 155 V6 TI 242 (75) BTCC Class 1 race engine
Alfa Romeo Type 33 V8 286 (137) 2000cc DOHC, Chiti design, 1967
Alfa Romeo 1600 261 (150) (with cams, generator, distributer, oil,
etc but no manifolds or carbs)
Buick/Rover 215 V8 318 (and Olds)
1987 black Milano Verde
1972 White spider 2000 Veloce
  #55 (permalink)
Old 07-03-2006, 05:43 AM
davbert davbert is offline
326lbs is what i got for 2000.
  #56 (permalink)
Old 07-12-2006, 10:20 AM
Keven's Avatar
I bought a scale on E-bay (I love E-bay ), not a comercial grade
one mind you, since those costs hundreds of dollars to weight something
around 400lbs. And for my puposes, I really want to see the difference
in weight between the S2000 and Alfa (motor & tranny).
Drumroll please.... And the weights are:
Alfa 1750 fully dressed minus header & air filter canister : 380 lbs
S2000 same as above but also with ac condensor : 380 + 43 = 423 lbs
So only a difference of about 43 lbs. Max, any need to change spring rates?
I had to use a bath scale under the tranny, because the hanging scale
only goes to 400lbs. Now its been a long long time since I took statics,
and I did not exactly ace that class. But if memory serves me right, my
set up should be ok, since the forces are in the same axis (though opposite
in direction), so they should simply add. Feel free to correct me if I'm
wrong. And as always here are a few pics of the setup..
For you nitpickers, I subtracted 10lbs for the engine tilter (which I weighed
separately) I have on the S2000 motor, thus the bath scale shows about
53 lbs in the pic.
  #57 (permalink)
Old 07-12-2006, 11:10 AM
Kev,can you shoot me a pic front on of the Hondola engine??
Thanks..
  #58 (permalink)
Old 07-12-2006, 12:23 PM
hmm how much is car battery? I think just moving the battery and you null the 43 lbs
I might be wrong but if you move 21.5 lbs to the back aka the battery
that will fix the 43lbs in the front.
and it will be less then that for real as the 43 lbs is spred out not all in the very front.
  #59 (permalink)
Old 07-12-2006, 04:15 PM
Keven's Avatar
Barry, I'm posting a pic of the front of the S2000 motore.
Slyalfa,
I am planning on using a dry cell battery that is only 12 lbs.
Good point as to the weight distribution. Now you have me
thinking of how to find the CG (center of gravity) of both
motors to predict effects on the front suspension. I can
tell you that since I cut the crossmember, the S2000 motor
sits lower and further back that the Alfa motor.
Is it me or, am I over thinking this?
  #60 (permalink)
Old 07-13-2006, 02:29 PM
finding CG
kevin
try this...
http://www.racerpartswholesale.com/longtech6.htm
davbert
