GTV-S2000 (warning not for the Alfa purist) - Page 38 - Alfa Romeo Bulletin Board & Forums
 4Likes
post #556 of 567 (permalink) Old 02-07-2013, 09:46 AM Thread Starter
Keven's Avatar
John, Where and when is the PV coffee and cars?
1978 Spider sold in 1996
Keven is offline
post #557 of 567 (permalink) Old 02-07-2013, 10:24 AM
1st Saturday of the month 7:30am-9am in the mall parking lot on the corner of Silver Spur and Hawthorne. You don't have to be old to bring your car...
http://www.pvseniors.org/pdfs/2013%2...0C%20Mopar.pdf
elisesile is offline
post #558 of 567 (permalink) Old 02-07-2013, 02:20 PM Thread Starter
Keven's Avatar
John, marked my calendar for March! See you there.
Keven is offline
post #559 of 567 (permalink) Old 03-01-2013, 06:22 PM
I will be there tomorrow morning Keven: 1967 Grey Porsche 912. Hope to see you and the car!
John
post #560 of 567 (permalink) Old 07-01-2013, 10:52 AM Thread Starter
Keven's Avatar
Ok I flaked for the last few months going to the Coffee & Cars show in Rancho Palos Verdes. See post above for info.
I will be there this weekend Saturday July 6th, so if anyone is interested
in seeing the "Alfa Tomato" come on down! Bring your car to show off as well!!
Keven is offline
post #561 of 567 (permalink) Old 07-06-2015, 09:31 AM Thread Starter
Keven's Avatar
So I was not happy with the dash cover. I read thru the BB's dash restore posts, and found lots of great info and decided to try it out on a dash I bought on E-Bay.
Here are a few pics of the material/tools I selected and used as well as the process of filling all the cracks. Initially I tried cutting the cracks with an box cutter to form a "V" thinking this would make for adhesion of the filler. It turned out that the larger gap (crack) I created was a lot harder to match in height to the rest of the dash, so I spent a lot of time adding layers of filler and sanding.
Keven is offline
post #562 of 567 (permalink) Old 07-06-2015, 09:42 AM Thread Starter
Keven's Avatar
And here is the finished dash with a bunch of coats of truck bed liner spray coat. I also added vents for my the Vintage Air Gen II Mini that I am installing (stay tuned for that update).
Keven is offline
post #563 of 567 (permalink) Old 07-06-2015, 10:33 AM
Subtle's Avatar
Good to see the thread continue.
Nice work on the dash.
Bob,
Director BC Chapter SNO.
Avatar is the 69 Super, bought new.
Current Ride: 67 Super, bought in 2013: Red/Black, "Tuned" 2 L.
Daily drivers, beginning in 1965: 750 Spider, Giulia Spider, 105 Sprint GT, 101 Sprint, 69 Super, 79 Alfetta Sedan. Collectors beginning in 2006: 101 Spider, 101 Sprint. Both sold.
Subtle is offline
post #564 of 567 (permalink) Old 07-06-2015, 01:53 PM Thread Starter
Keven's Avatar
Here's a preview of starting the install of the Vintage Air Gen II Mini air/heat unit. So to fit the unit I had to move the main fuse box into the engine compartment, and in general move the wiring harness all around to make room to be able to place the unit behind the glove box. No simple task!! So I took out the dash and pretty much stripped the interior. I added Dynamat Extreme to the firewall. It took 12 sq ft to cover it all, and that stuff is not cheap! I also had to redo the center console to add the control panel for the air/heat unit.
So why go to all this trouble? Well, the unit I installed was very weak, and did not adequately cool the cabin, was noisy and I could not control separately the defrost and dash vents, so it would cause condensation on the windshield if I ran it for prolonged periods of time (annoying!!).
Here's a few pics to start, more to come...
Keven is offline
post #565 of 567 (permalink) Old 01-26-2017, 10:05 PM
Hello did you get the car running? My ecotec is about 1-2 months away from running
anyone can buy a Porsche, only Drivers drive a Alfa Romeo
bianchi1 is offline
post #566 of 567 (permalink) Old 01-26-2017, 10:08 PM
And what is the power like, mine was dinoed at 197 hP at 6400 and 183 ft/ lbs at 3600,an pretty flat range,130 ish from 1000 rpm
bianchi1 is offline
post #567 of 567 (permalink) Old 03-17-2017, 10:28 PM
alfaman's Avatar
kevin...how is your dash holding up...did the cracks reappear?
IanB likes this.
1969 spider
1971 gtv
1972 berlina
alfaman is offline
