GTV-GR, I did not use the rear end of the S2000, looks like some
really major fitment issues, as well as structural mods to get the
correct mount points, and rigidity.
I just got the drive shaft back from the shop (Driveshaft Masters
in Harbor City). Man it's short! I also stripped down the rear section
to replace the u-joints. The front part is made by the stock S2000
drive shaft CV-joint, and welded to the Alfa front shaft with the
center support bearing. After checking if it all fits, I will take it
all into the driveshaft shop and have it all dynamically balanced.
As usual some pics for your enjoyment
