Accelerator (sp?) pedal and cable are in. I cut up the Alfa's
pedal linkage, and rewelded the cable clamp real close to the
pedal. I then used the stock Alfa linkage bushings bolted to
my tranny tunnel. I still need to add an e-clip to hold it in place.
But, travel is perfect, with some chance for adjustment at the
throttle body. The cable is stock S2000 with the rubber end
cut off, and then the cable is threaded thru the Alfa's linkage bolt.
Note the cheesy rivet head used to keep the cable from fraying.
I need to get down to the bike shop to get some real cable ends
The clamps are from Honda, and work great to hold it all in place.
Up next the fuel tank and plumbing...
