#241 (permalink)
Old 12-16-2007, 06:32 PM
Mikes4C1300's Avatar
Mikes4C1300 Mikes4C1300 is offline
Originally Posted by Keven View Post
The S2000 tank has the fuel inlet on the passenger side, ...
Keven,
For what it's worth, the stock S2000 filler is on the drivers side of the car. Does this make a difference? It looks like you've made a lot of modifications to the tank.
Mike Hollinger
Atlanta
'60 Giulietta spider, '67 GTV, '02 S2000
  #242 (permalink)
Old 12-16-2007, 06:39 PM
sh0rtlife's Avatar
sh0rtlife sh0rtlife is offline
must have turned the fual tank around?
thats some nasty looking cancer you got on that rear windshield surround
sweet looking gas cap...how big is the actual cap? and what did ya pay for it if ya dont mind me asking........im currently fighting to figure out what im going to do n my lloyd for a gas cap(originaly the tank was under the hood with the 2cyl now to be in the rear with a 2.5 alfa up front)
[SIGPIC][/SIGPIC]
  #243 (permalink)
Old 12-16-2007, 06:51 PM
Keven's Avatar
Keven Keven is offline
Yep, the fuel tank is turned around or reversed. I don't think
that it will cause any problems, as the there is a pan that
acts as a baffle for cornering, and accelerating to prevent
fuel starvation. I think it should work ok in any direction.
I am worried about filling the tank, as the feed line/hose
from the cap will be at very slight angle.
The cancer is bad, but some metal fab, and welding should
clean in all up nicely. I think that most GTV's have this problem,
as the gasket holds water against the metal lip, and slowly
rots it away. I am wondering if using some POR on these
areas will cure any future problems there.
The cap costs $80, and the funnel $70 all from:
BAT - MOCAL Oil Control Systems
1978 Spider sold in 1996
  #244 (permalink)
Old 12-16-2007, 06:56 PM
PSk PSk is offline
Keven,
Have you had a look at race shop fuel tanks, ie. the safety plastic ones with the foam inside?
They might have a rectangle cube shaped one that will fit between the rear shock towers much neater than the Honda one ... just a thought . Then you would maintain a lot more boot space.
  #245 (permalink)
Old 12-17-2007, 12:54 AM
sh0rtlife's Avatar
have to agree..id be happyer running a fuel cell personaly
a well primed(epoxy/rustproof primer) and then a good top coat at the same time you paint the car "should" prevent any of that from ever happening....
dont worry to much about the angle of the fuel inlet..thats why the pumps have a curved nozzle ..ive seen some VERY curved fill necks...you should see the neck on my 58 ford
[SIGPIC][/SIGPIC]
  #246 (permalink)
Old 12-17-2007, 02:41 AM
BigSwede's Avatar
BigSwede BigSwede is offline
Originally Posted by sh0rtlife View Post
LOL actualy the fuel tank is grounded for 1 single reason...fuel level sender..no ground=no signal
All parts of the filler neck and tank must be grounded, static electricity develops when you pour gas and unless there is ground it can ignite.
Mats Strandberg
  #247 (permalink)
Old 12-17-2007, 08:12 AM
Mario R.'s Avatar
Mario R. Mario R. is offline
And the filler hose from the pump has an internal ground wire. There have have been a number of fires after someone replace the special pump hose with ungrounded hose.
  #248 (permalink)
Old 12-17-2007, 03:09 PM
5yearplan's Avatar
I wouldn't go with a plastic tank on a street car as they are hard to seal completely and the trunk will end up filling with gas fumes... a little dangerous also. Another problem with foam instead of baffles is that they absorb alot of gas, my friend had a plastic 11 gal cell in the back of his car for a few weeks (the old tank had rusted out) and he didn't even have 8 gallons of usable gas. But there are some nice steel fuel cells out there, in about every shape and size.
[SIGPIC][/SIGPIC]
You should buy my stuff: [url]http://www.alfabb.com/bb/forums/showthread.php?t=44309[/url]
Restore and Engine Conversion:[url]http://www.alfabb.com/bb/forums/showthread.php?t=46024[/url]
  #249 (permalink)
Old 12-17-2007, 03:56 PM
PSk PSk is offline
Foam absorbs hardly any fuel, infact I would say it's not noticeable ... my last race car had a plastic foam filled tank ... brilliant IMO. Weird to fill up because you could not see the fuel, just the blue foam ... until all of a sudden it was there. Also this plastic tank had a bolted on fuel gap thingie, thus it would be easy to make something that bolted on exactly the same way.
Maybe the foam was different to your friends, but IMO ALL fuel tanks should have this foam installed.
The only reason passenger cars use baffles and metal tanks is cost ... and they simply don't care enough about their customers. That is why many new cars are still made with the petrol tank hanging out in the boot floor just waiting for that rear ender.
  #250 (permalink)
Old 12-17-2007, 06:51 PM
5yearplan's Avatar
yeah, it wasn't very expansive, plus he was using a top mount in tank pump which may have made a difference
[SIGPIC][/SIGPIC]
  #251 (permalink)
Old 12-18-2007, 12:06 AM
BigSwede's Avatar
The reason all fuel cells have a 5 year life is because the foam deteriorates. I'm not sure people would love to change their tanks every five years.
Almost all new cars have their tank in front of the rear axle (under the rear seat), can you give me an example of something that has it under the boot?
Mats Strandberg
  #252 (permalink)
Old 12-18-2007, 04:21 AM
drew`SEVNT5 drew`SEVNT5 is offline
not a new car...but the alfa 75 twinspark had its 49l tank behind the axle, under the boot
[CENTER]-1990 Alfa Romeo 75 3 litre V6...Twinspark Bumpers-
-2005 Ford Falcon XR6 Turbo-[/CENTER]
  #253 (permalink)
Old 12-18-2007, 05:38 AM
cowfy cowfy is offline
great someone brought that point up.i've had alfetta based cars with the fuel tank under the *** so to speak and others with the tank over the axel.i wonder if momentum is is affected better in one case or the other?
  #254 (permalink)
Old 12-18-2007, 11:31 AM
sh0rtlife's Avatar
does it mater who made the fuel cell?...ive got one here thats about 10 years old and the foam in it is like new..hasnt deteriorated one bit
[SIGPIC][/SIGPIC]
  #255 (permalink)
Old 12-18-2007, 04:07 PM
PSk PSk is offline
I'm reasonably sure the Ford Falcon and Holden Commodores sold in Australia have the fuel tank mounted in the boot still ...
But agree infront of the rear axle is the best place (like an Alfa Sud).
