Yes, I agree the radiator looks like crrraaappp
But it is being rebuilt as I type with a three row high efficiency
core. The outlets are being moved to the driver side with
45deg bends to ease hose installation. It is also having the
S2000 fan attach points brazed on, as well as the S2000
fan switch bung. The reason I am sticking to a brass/copper
radiator, is that I have had very good results with my other
cars using high effciency cores, as well as them lasting over
20 years without leaks or problems. The Alfa Tomato will be
a driver, with some limited track time, so I want durability/reliability.
While I am waiting for the radiator to come back, I have decided
to start working on the gas tank. The tank I have is (yes, you
guessed it!) from an S2000 as well. I am modifying it to sit over
the axle in the rear most for safety, and better weight distribution.
I think that the cut out will remove about 5 gallons, still leaving
me about 11 galons of fuel. I will add bungs on the bottom of
the tank to bolt it from the bottom, as well as a strap to hold it.
The fuel pump is stock S2000, and I am debating as to the use
of a single braided flex line to the engine bay, or use short braided
lines to a couple of aluminum hard lines. Any advice on this?
Should the lines be run under the car or inside the cabin? Which
is safer?
Some pics for your enjoyment...
