105 Twin Spark Engine Oil Level - Alfa Romeo Bulletin Board & Forums
Old 03-15-2010, 03:16 AM
njh1964's Avatar
I'm hoping someone can help with these questions, related to dropping a Twin Spark engine into a 105 Alfa:
(a) After you swap the stock Alfa 75 Twin Spark sump over to the 105 "bat-wing" design sump, what total volume of engine oil will the 105-sumped Twin Spark then require? Obviously, I don't want to overfill or underfill the engine oil.
(b) After the abovementioned sump swap over, will the stock Alfa 75 oil dip stick then show an accurate reading as to the oil level in the Twin Spark engine?
Regards,
Nick
Now: 1969 Alfa Romeo GT 1300 Junior - restoration project
Previously: 1974 Alfasud TI - first car
Old 03-15-2010, 04:26 AM
crashmctavish's Avatar
I had the same debate, search for a post called dipstick.
Originally I used the 75 dipstick without problem.
I am now using the original 105 motor stick, remember you have fitted the 105 oil pump so the pick up only needs a 105 oil level.
Mind you if you use the 75 stick which is perfectly safe, you will never run out of oil ! as the qty is the huge!
[I]Regards Keith, GTJ Twin Spark[/I]
Old 03-15-2010, 05:03 AM
105 Twin spark engine oil level
When converting the TS engine in our Giulia, I have used the original TS dip stick. After filling up the engine with 6,5 liter oil I have made a indication of this level on the dip stick as max indication.
This enables me to easily verify if level is ok.
Arthur
Alfa Sud 1.2 ('79) con 27.133 km!!!!!!!!!
Giulia NS 1.3 TS ('77) / GT Junior 1300 ('75)
75 TS A.S.N.1382 / 156 SW JTD
Guzzi 850 Le Mans I
Old 03-15-2010, 04:57 PM
njh1964's Avatar
Hi Crash,
I was worried that searching for the word "dipstick" may have returned a photo of myself ... but you've now put my mind at rest.
As for using a 105 dipstick, that sounds like an idea, but so does MIaGuilia's suggestion of re-marking a maximum level on the 75 dip stick, which I already have.
Also, I'm concerned about overfilling the engine with oil, as this can be as problematic as underfilling it.
Hi MIaGuilia,
Given the significant shape (and possibly volume) difference between the 75 and 105 sump pans, I'm wondering what the best recommended oil volume is for a Twin Spark engine with a 105 sump. How did you arrive at the figure of 6.5 litres?
Regards,
Nick
Old 03-15-2010, 05:29 PM
You cannot overfill it
The 75 stick is fine, but can you afford so much oil! It will not thrash the crank webs, it will take 20 miles to warm up!
The 105 stick is fine coz it was designed to work with that pump.
