I did my own electronic, stripped out the orginal pod, mounted a 75ts tach in the pod with original fascia & needle. Use the white wire from the ignition coil packs for the signal.
Easy ! No not really it took a lot of fiddling, but works.
[I]Regards Keith, GTJ Twin Spark[/I]
