I'm not sure if this question is best asked in this forum or in the engine-management forum - but I'll try here first anyway.
I want to add EDIS ignition, probably programmed from a Megajolt ignition ECU, to my 1974-ish 2000 engine. The engine is out of the car and I'm working through the usual pair of problems with doing this - how to mount the 36-1 trigger wheel to the crank pulley - and how to mount the sensor.
Concentrating on the pulley for now, I came across this pulley from Centerline.
Centerline Products: CP607 Crankshaft Pulley - 2000 Engine (Bosch Injected)
very nice looking piece AND with 4 threaded holes for the mounting of 'something' to the front of it. I've never had a Bosch injected car so am not sure what is usually bolted there...but I want to bolt a trigger wheel there.
Therefore the question is - would this pulley line up with my alternator/water pump? and would it seal in my timing cover? Or did they change things in '82 such that this pulley is useless?
-Richard
Scotts Valley, CA
