Old 08-18-2009, 09:02 AM
MONOSLEEVES for alfa 75 2.0
I have heard about a company manufacturing monosleeves located in Italy. Does some body knows anything about this company, name, phone no, link or any thing that can help is greatfull.
Thanks in advance
Mende, Denmark
Alfa 75 ts turbo, full race
Alfa 75 v6 3.8 24V, full race
Best regards
Mende
Alfa 75 TS Turbo, race car
Alfa 159 SW 1,9 JTDm, not race car
Old 08-27-2009, 11:28 PM
4sfed's Avatar
Thanks in advance
Mende, Denmark
You can get one in the US . . .
Alfa Romeo Performance Engines
Old 08-30-2009, 10:14 AM
GTV-GR's Avatar
too much money dude for a mono
tell u what- i'll save u , get some epoxy and glue them it's roughly the same all the racers do this
Old 08-30-2009, 10:54 AM
Tifosi's Avatar
Darth Slacker
Ah, but a monosleeve like the one above has just held together for a world record 230+mph run on the Bonneville salt flats, and who knows how many other runs it made in that engine 'til the record was finally reached. (care to share Jim?)
I'm guessing glue won't quite hold up to that standard.
Darren
as hosted by
Greg Gordon's HI Performance Store
& OK Injectors
Old 08-30-2009, 02:08 PM
4sfed's Avatar
I have several engines running with epoxied liners and one with the monosleeve . . . there's no comparison. If you can avoid any detonation or overheating, the factory liners work fine . . . but it doesn't take much to blow a head gasket or split a factory liner.
In 2006 I rattled the engine hard enough to crack the plugs, but the head gasket didn't fail and the monosleeve didn't split. We also had a radiator that was too small for the additional horsepower and I boiled all the water out of the engine each run, but managed speeds over 220 mph . . . still no liner or gasket failures.
Over the years, several sleeves in this monobloc have been replaced because of corrosion . . . it's hard to imagine how quickly things rust when exposed to the Bonneville salt . . . but it's still running the original pistons that were installed for 2005.
I'm convinced it's a necessary part of the Bonneville program . . . OEM liners would not take the abuse. Is it overkill for a normally aspirated engine? Probably, but I understand the Novamotor F3 engines used them. YMMV.
Old 08-30-2009, 03:09 PM
Tifosi's Avatar
Darth Slacker
Originally Posted by 4sfed View Post
Is it overkill for a normally aspirated engine? Probably....
I still wanna have one at some point in the future but the missus keeps piddling cash away on stupid crap like mortgage payements and 'bills'.
Darren
as hosted by
& OK Injectors
Old 08-30-2009, 04:15 PM
4sfed's Avatar
You could install a turbo . . . then it would be "necessary".
Old 08-30-2009, 10:49 PM
monosleeves
I have turbo in my 75 with engine from 155. The engine and liners are so far good no problems with power up to app. 300-330 Hp.
The problem with stock liners is that they crack where they are thinnest, of course it could be a matter of engine power and detonation.
I have not had any problems in my own engine but I still keep the power output down below app. 300 Hp.
Last week we tested my freinds 75 he bought from Nick Humphrey, it pushed easy more than 360 Hp with out any problems, still without monosleeves, but some special made sleeves.
I still think above 350 Hp it would be a great idea with the monosleeves.
Any idea what this monosleeves cost?
Best regards
Mende, Denmark
Best regards
Mende
Old 10-18-2009, 02:30 AM
Savali (Netherlands) has some 2100 monosleeves laying around, would those do, or do you need to stay below 2000cc?
Old 10-26-2009, 06:59 AM
GTV-GR's Avatar
tifosi dude... Jim is NASA spec , i'm talking the occasional race , hillclimb etc you don't need mono for 200hp
Old 10-26-2009, 07:45 AM
Tifosi's Avatar
Darth Slacker
I didn't say I need one, I said I want one.
Darren
as hosted by
& OK Injectors
Old 10-27-2009, 06:56 PM
GoldCloverLeaf's Avatar
Send a message via MSN to GoldCloverLeaf
Beninca in Australia also sell monosleeves to suit the Nord and TS: Special Parts
Not sure on price but not cheap by any means...
Another option is to use the Alfa 155 Q4 turbo 16V engine (really a re-badged Lancia Intergrale engine), however there is a fair bit of work as this is a transverse mounted engine.
However, the 16v head mates up to the Fiat 2L as found in the RWD 131, 132 and others with very little modification.
But of course, fitting a Fiat block with what is essentially a Lancia head is sacrilege to most Alfisti! But certainly a cheaper option for those seeking BIG HP that want to keep it Italian…
As a side note, Australia’s fastest 4cyl for a awhile was a Fiat block / Lancia 16V powered, street registered Datsun 1200 with a large TO4Z turbo that has run 7.66 down the ¼ mile
'74 105 GTV 2000 - Resto project
Old 10-28-2009, 12:24 AM
These fiat/lancia blocks require heavy modification to go over 300bhp as well. They do have 16 valves, which helps flow a lot.
  #14 (permalink)
Old 11-10-2009, 11:19 PM
Storm_X's Avatar
any one have any pics of the epoxy trick ?
"Alfa Romeo built to excite .. Some dream of driving the ideal.. I drive it"
  #15 (permalink)
Old 11-11-2009, 06:54 AM
4sfed's Avatar
What are you wanting to see? Once the liners are installed, there is no difference in appearance except a bead of epoxy around the bottom of the liners.
