V-6 to 115 trans bellhousing - Alfa Romeo Bulletin Board & Forums
Old 07-29-2009, 09:55 PM
I'll start this off from current point and go back., first cast conversion bellhousing picked up from foundry, A365 and heat treated, now to work up CAD file for machining. The mold plug is the tan colored bellhousing.
My car is up and running with one of my original sandwich bellhousings.
Decided that a cast part would be easier to offer for sale. I have my motor mount jig, oil pick up jig, header jigs, oil pan set up all done.
I have previously sold six bellhousings alone, they included the custom T/O adapter, clutch disc and pilot bushing and a complete kit with stainless headers.
Larry
Old 07-29-2009, 10:10 PM
My set up is a bolt in, no cutting required to install a V-6 into a 105-115 chassis. I choose to use the 164 stick flywheel and push type pressure plate with a custom disc with 164 size diameter and the 10-1 spline of the standard trans. the bellhousing uses the 164 gear reduction starter, very light and great cranking. Net overall lenght is same as stock 4 cyl bell so trans stays in original mounts and location, no tunnel cutting.
The standard 5sp has proven itself to be pretty strong, so far no probems in my car, My 12V 3.0 with 11-1 comp and large cams, etc.=195 at rear wheels approx. 230-235 at flywheel.
Larry Jr.
Alfa Parts Exchange
Larry
Old 07-29-2009, 10:15 PM
Here is the test mule and cut down chassis for fitting, building the 304 stainless headers
Larry
Old 07-29-2009, 10:20 PM
more header fab. I really enjoy making them, similar process back when I made stainless headers to put the 24V in my GTV-6. Once the first set is done then the jig is made to make future sets easier.
Larry Jr.
Alfa Parts Exchange
Larry
Old 07-29-2009, 10:26 PM
The custom oil pan, Alfa 6 pan turned out to be more problems so I move to just TIG welding new rails to the 115 4cyl. pan and made a custom oil pick up for the 164 type oil pump. The pan in the car looks like a stock 4cyl powered car from underneath. The dual down pipes give it away though.
Larry Jr.
Alfa Parts Exchange
Larry
Old 07-29-2009, 10:37 PM
The fresh hot engine ( last year)ready to go in. That is the old type bell housing I made, someday I'll pull in one of my new cast ones.
Larry Jr.
Alfa Parts Exchange
Larry
Old 07-30-2009, 06:11 AM
kredden's Avatar
Larry,
Any issues with cooking the tranny oil with the pipe running right under it?
Kevin
87 Verde
86 GTV6
67 Super
88 Verde (Scuderia Limoni 24 Hrs of LeMons)
Milano registry custodian(www.alfamilano.com)
Old 07-30-2009, 10:14 AM
No heat problems, pipe has fair air gap, picture doesn't show it that well, and stainless has great insulating properties. I could wrap it at some point.
The down pipes go into a Stradale GTA exhaust system, sounds pretty good.
Larry Jr.
Alfa Parts Exchange
Larry
Old 07-30-2009, 11:22 AM
That looks great. got a price list yet? and ETA!
"The dual down pipes give it away though."
I would think the sound would be the give away
1987 black Milano Verde, 1987 (made in 1986)blue $200 gold with ABS
1972 White spider 2000 Veloce
Old 07-30-2009, 07:25 PM
im interested in buying one of your kits please call me my cell is 1 914 494 0477 ask for alfonso thank you
Old 07-31-2009, 10:02 AM
Here is a few shots of the finished headers, passenger side is very tight due to the engine offset. I had all the flanges cut from 304 stainless 3/8 thick.
Larry Jr.
Alfa Parts Exchange
Larry
Old 07-31-2009, 01:23 PM
kredden's Avatar
Nice!
Kevin
87 Verde
86 GTV6
67 Super
Old 07-31-2009, 09:21 PM
raff_gta's Avatar
awesome work there mate, mighty impressed!
i cavalli mai abbastanza, ed il peso sempre troppo...
  #14 (permalink)
Old 07-31-2009, 10:10 PM
Very good work - impressive problem solving.
  #15 (permalink)
Old 08-01-2009, 12:41 AM
Larry, in your opinion, what are the chances of being able to fit a header with the starter motor on that side and where a RHD steering box would sit?
1966 Giulia Sprint GT Veloce - pretty much finished!
Bunch of bikes too.
