My bellhousing is tilted and offset for a left drive, I don't have the right drive parts for mock-up, the motor mounts could be offset to move the engine to the left, left drives are offset to right making it very tight on the right. The bellhousing that someone in Australia made had a greater tilt, to make more room on the right side,mine is 5 deg. as stock on the 4 cyl engines.
the 3.0 V-6 is only 40lbs. heavier than a 2.0 and is shorter, mass is slightly rearward of a 4 cyl.
I have been hard on my home additions, but the CAD for the bellhousing is almost done.
Larry
Larry
