Old 07-17-2005, 09:21 AM
wesley55's Avatar
wesley55 wesley55 is offline
TS Conversion
Has anyone
1) Bought the Colombo Bariani cams?
75/155 Twin Spark 8v
ARTS.121.280S set Stradale Medio 12.1 10.5 30° - 70° / 65° - 25° 2.6 / 2
ARTS.114.300C set Corsa Medio 11.4 11.4 45° - 75° / 72° - 42° 4 / 3.8
http://www.colombo-bariani.com/catal...ac73dd16bfacc2
2) Does anyone have experience with the higher compression piston liners offered by OKPARTS and EBSpares for the twinspark conversion-will it work with our pump gas?
3) Will an electronic ignition straight from a Milano 75 twinspark triggered off the front pulley work straightoff?
Old 07-17-2005, 09:22 AM
wesley55's Avatar
Btw
Jim (may I call you Jimmy the Greek?);
When are you coming out with the twinspark conversion book?
Old 07-17-2005, 10:32 AM
Jim K. Jim K. is offline
Jimmy the Greek was supposedly a card playing character in Vegas (??), I don't know if he had anythingto do with Alfas! I'll bet the guy was loaded though, I'm one of the poor ones!
The editor will decide when to come out with the book and it's still in my hands being re-written, supplemented and revised - rebuilt, with better parts to be more accurate.
If you retain the toothed wheel, pickup and ECU the ignition will work. However, the 3D feature also requires the load input from the AFM. Will you retain that? And if you do how do you propose to properly feed the Godzilla cams? Check that the vvt with these cams will not foul the pistons!!
Jim K.
