06-23-2009, 05:34 PM
Dear Papajam,
If you could email me the diagram for a 73 gtv, I would be very grateful. I think I remember you saying that this diagram had been cut into to two pieces. If so, I'm trying to trace the horn and the wipers.
You're a saint or a god, one or the other. Either way, thanks a thousand times.
Here's my email: jf@labindc.com
06-23-2009, 05:53 PM
Trained Professional
One piece 11x17 diagram sent.
And thank you for the kind words!
Series 1 Euro 1750 GTV
Series 2 USA 1750 GTV
Series 3 Spider Veloce
06-25-2009, 07:57 AM
'73 GTV wiring diagram
I sent a PM with thanks, but I would like everyone else to know what a great service you're providing to those of us with Alfa Romeo disease.
Thanks again.
06-26-2009, 06:20 AM
Member
10204 Rolling Restoration in Ct.
Dear Papajam,
Could you provide me with a wiring diagram for a '60 AR 10204 Roadster?
Thank you, Roger.
rwce@cox.net
06-27-2009, 06:01 AM
Member
Diagram received....Thanks very much!
Roger
06-29-2009, 05:34 PM
11541 2000 Spider 1982 R7
Dear Papajam
I would appreciate a copy of the wiring diagram for the 1982 alfa spider
Thanks you so much.
My email address is vtshyam@fligh****chintl.com
Thank you again
07-02-2009, 06:48 AM
Hi to all,
i'm Mattia from Italy, i have a Giulia super 1300 (115.09), i'm looking on the net for a copy of the wiring diagram for this car.
If someone can help me matyas(at)tiscali.it
thanks to all and have a nice day
07-02-2009, 04:49 PM
Welcome, Mattia.
Your diagram has been sent.
07-03-2009, 07:17 AM
looking for your diagram 10562 1750 Spider 1969 R6
Good Morning Jim,
I see by your post that you may have a wiring diagram for the '69 1750 Spider, if so may I get a copy of it. I've got a minor rewire to do and want to make sure I do it properly. Thank you for your efforts and your reply.
Cheers,
Bob Worden
1969 1750 Alfa Spider "Sofie"
07-03-2009, 09:30 PM
looking for wiring for early 1985 spider veloce
My dad recently picked one of these up and they were in the process of removing the engine to make a race car. (they unplugged everything and we are trying to hook it back up) We are setting the car back to original and need a wiring diagram but the manual we ended up with for the 1985 shows a different instrument cluster, etc. so we think we have essentially the last of the 84 style dashes in our car. don't know alpha's that well so may be completely off base. Any help would be appreciated.
07-04-2009, 03:32 AM
bworden,
Diagram has been sent.
jaymo,
I've never seen an Alfa published wiring diagram for the 1985 model year nor do I know if Alfa even published one. However, my understanding is that the chassis wiring for the 85 is the same as the 84 while the Bosch L-Jet wiring for the 85 is the same as the 86. If you send me your email address in a private message, I'll send you both the 84 & 86 diagrams.
07-07-2009, 12:57 PM
Member
headligtht problem
I could really use the diagram for the high beams. Does it have a relay, and where? Don Epstein
07-07-2009, 01:45 PM
Hi Don,
Knowing the year and model of the Alfa in question would help considerably.
07-07-2009, 09:42 PM
Member
need for wireing diagram
First.thanks for the help. I have a 1986 Alfa Graduate..vin#ZARBA541XG1044197. It was bought in White Plains, NY from Al;fredo' Alfa/Maserati in June of 1986. Hope that helps. Problem is al of a sudden I have no high beams or the indicator on the dash. All other lights, and the low beams work. Suggestions will be greatfully accepted. Don
07-08-2009, 07:51 AM
First thing I'd do is check voltage (or use a test light) on fuses #13 & 14 (assuming that the fuses are good, and clean) with the headlight switch in the highbeam position. These fuses are on the far right of the fusebox. If voltage (or the test light lights), the problem is downstream of the fuses; if no power, the problem is upstream. Also check that the multipin connector at the lower right rear of the fusebox has not come loose.
If you'd like a wiring diagram, please PM me your email address.
