#331 (permalink)
Old 03-18-2009, 03:52 PM
papajam's Avatar
Trained Professional
Diagrams to jg1053 & agamba76 have been sent.
Series 1 Euro 1750 GTV
Series 2 USA 1750 GTV
Series 3 Spider Veloce
  #332 (permalink)
Old 04-04-2009, 02:34 PM
Biba69's Avatar
'79 Sprint Veloce Heater - A/C schematic
Jim, you sent me the overall wiring diagram for this model (with A/C) and I thank I you. I had an 18" x 36" color copy made from your .pdf. Beautiful.
I'm sure you included every wire for the heater and A/C from the information you have available to you. I strongly suspect these dual units were installed in the US, and no complete wiring diagram was ever made for the separate units.
In any event, I'm including photos of what I'm up against when I (try to) eventually install the units in my '75 Alfetta GT. There are three switches: Defrost (heater fan); A/C temp.; A/C fan. Additionally three wires go to the engine bay. The only one I have identified is the one to the dryer. I have a yellow wire on the A/C fan relay which I've labeled Engine bay ?? on the second to the last photo. I feel it must also turn on the fan for the condenser. The wiring on the relay appears to have been fiddled with so I'd very much like to know how it should be wired. The relay is on the second to the last photo.
On the last photo I have the (green) heater fan switch upside down in the photo. I've shot myself in the foot in that I labeled the connectors alphabetically and I'm sure I then made a diagram (which I can't find) of where each goes. The unfortunate thing is there are (very small) numbers by each contact on the switch which would have made reattachment a cinch had I used them. You in turn have them identified as BCLMH. I would sure like to know what the letters stand for. The wires I labeled with a ?? were unattached or disappeared into the wiring loom.
I'm sure I'll have to include all of the photos in at least two posts.
I no longer have the '79 Sprint Veloce. Therefore these units, for now, are useless to me unless I can identify all of the ?? wires. However if the information doesn't exist, then I guess that's the end of it. You can see there are roughly 20 wires not included in your diagram - and as I said, I'm sure you worked with what info you had available.
So I'll also ask if anyone else out there has gone through this same process and made better notes than I did or could have.
Biba
  #333 (permalink)
Old 04-04-2009, 02:37 PM
Biba69's Avatar
'79 Sprint Veloce Heater - A/C photos (continued)
  #334 (permalink)
Old 04-05-2009, 02:12 PM
papajam's Avatar
The BCLMH blower switch terminal designations are what's written on the original Alfa wiring diagram in the owners manual. Hence, these same designations are on the color diagram as well.
What do they stand for? Well, haven't a clue what the 'B' is (black wire to A/C temp switch) but I'll guess that the 'C' is the 'Common' since it's the hot input to the switch. The 'L, M & H' would appear to be the blower speeds; Low, Middle (or medium) & High (that go to the resistor with one wire [yellow/black 'H'] splitting off to the blower).
  #335 (permalink)
Old 04-25-2009, 01:25 PM
Junior Member
help
Do you have a wiring diagam for a 1986 graduate with blade fuses and ac? please help i am not getting power to the coil thank you kardell.e@cox.net
  #336 (permalink)
Old 05-04-2009, 03:24 PM
Hi Papajam,
I need a wiring diagramm for my Giulia Sprint GT number 10502 in your list. It would be very nice if you could send it to me. martinobreuer@hotmail.com
Thanks!
  #337 (permalink)
Old 05-06-2009, 05:09 AM
hi i have just joined and have a 1986 1.6 spider s3 which has just had a wiring melt down so am desperate for diagram...please help
all the best wook3y
my e-mail address is marcuswookey@googlemail.com
  #338 (permalink)
Old 05-16-2009, 05:48 AM
Hi Papajam
I am a new member and I find it would be very usefull to get the wiring diagram for my 1963 giulia Spider 10123.
Thank-you in advance for your help
  #339 (permalink)
Old 05-16-2009, 06:53 AM
papajam's Avatar
Welcome to the AlfaBB, kinou.
I would be happy to send you the wiring diagram for your Spider. Please send me your email address in a private message and I will get it to you.
  #340 (permalink)
Old 06-04-2009, 02:34 PM
Hi - New member in desperate ned of diagram
Papjam
I would be incredibly grateful for the following diagrams;
11502 2000 Spider 1972 R2.1
11502 2000 Spider 1973 R2
my email is liam.reading@southhams.gov.uk
Many thanks.
Liam
  #341 (permalink)
Old 06-15-2009, 10:14 AM
Hi papajam.
I am not sure that you received my PM.
Do you have the wiring diagram for a GTV 2,5 (V6) from around 1985, it is only the diagram for the engine (ignition, injection and fuel pump) i need.
If you donīt have it in colour, please send a copy in black & white
Many thanks in advance.
Martin.
My mail is:
martin-rehberg@hotmail.com
  #342 (permalink)
Old 06-18-2009, 02:40 PM
Hi Papajam
I would very much appreciate the wiring diagram for a 1968 1750 GTV Series 1.
I'm a bit stuck, pulled out the wiring but didn't quite label the terminations well enough.
My email jon1750@hotmail.com
Thanks for your great efforts.
  #343 (permalink)
Old 06-18-2009, 03:25 PM
I have a 1976 spider 2000 , If you have the diagram for this model , It will be greatly appreciated . Thanks
  #344 (permalink)
Old 06-18-2009, 03:55 PM
papajam's Avatar
jon1750,
Your diagram is on the way.
hmayg1,
Please send me your email address and I'll send you the diagram.
  #345 (permalink)
Old 06-18-2009, 03:59 PM
my email is may1@us.ibm.com
