Old 02-08-2009, 04:05 AM
164 3.0 24v v6 need wiring info/help
Hi
I have a 164 as per the title and it has a wiring issue with the coilpacks.
Basically one of the front coilpacks is not getting a signal to fire so I started to trace the wiring fron the coils and injecyors only to find it goes to the rear of the motor before returning to the plug near the rear of the front head.
Was going to pull the plenum and rear cover off to trace the wire and hopefully find the break and fix it but was wondering if someone had a wiring diagram they could post or e-mail me of the injector and coilpack wiring as this would/could save me a lot of time trying to fix it.
It is getting real annoying driving around on 4 to 6 cyls as the problem comes and goes when it feels like it.
Thanks in advance
Old 02-08-2009, 01:08 PM
Alfissimo Int.'s Avatar
Registered Alfa Addict
Originally Posted by ozmick View Post
Hi
Thanks in advance
Hope this helps. The wiring harness for the spark plugs is a common replacement item. I do have some in stock if needed.
Jason Minos
<-GT Bertone, Spider, 75, GTV6, 164, all New models->.
http://www.alfissimo.com Alfa Parts
Tel: +1 480-858-9156
Contact@alfissimo.com
Alfaparts@alfissimo.com
<1991' 164 QV, White- Recaro>
Old 02-09-2009, 04:45 PM
goats's Avatar
War on string is winnable
Sounds like a bad ignition module
located just under the airbox on the 24V car, there are two of these, and if one is failing, or the connection to it is dodgy, gives exactly the symptom you describe. I would check the connections there first, clean them up, etc and then swap the connectors to see if the problem moves (module dodgy) or stays on the same cylinder (wiring) -- also check the big circular connector and clean that up too
goats
74 GTV with 10548's and Ingram pump speedo been around at least twice!
1995 LS Q runners squadra chip Auto Green/tan 163K 100% LCD
1995 LS 5 speed Green /tan 38K Q runners 100 % LCD!
Misc parts laying around for 24V and 2Liter!
2004 Tacoma 4 door TRD (wifes car/kid hauler)- 86K
Mission Vsi, Mission Mod 2, Mission D2 - 10+ years of hockey on these!
radio flyer- rusty from disuse!
