3-wire windshield wiper wont park properly - Alfa Romeo Bulletin Board & Forums
post #1 of 6 (permalink) Old 05-19-2017, 07:24 PM Thread Starter
james2000's Avatar
I am experiencing a vexing problem with the park function of my WW motor. After a time consuming search I was lucky to source a used working original 3-wire Bosch motor for my 1750 GTV. Unfortunately, although the wiper does a good and complete sweep of the windshield, it parks about 6 inches too high from the bottom of the windshield. If I manually reset the parked wipers to the bottom of the windshield, the down sweep of the wipers ends up beyond the windshield frame and onto the cowl. I am wondering if the problem can be solved by repositioning the cogged wheel in the motor drive. The only change to the original system is the foot switch has been eliminated entirely from the electrical network. Its only function is to pump wiper fluid.
Has anyone experienced this phenomena? Any suggestions would be much appreciated.
1970 GTV (owned since 1987)
1985 GTV2.5
james2000 is offline
post #2 of 6 (permalink) Old 05-20-2017, 02:32 PM Thread Starter
james2000's Avatar
I think I figured it out with the help of Google.
The motor is out of sync with the positioning of the wiper linkage (and the wiper blades). To get it back in sync, I need to disconnect the motor from the linkage. This is necessary to free motor's shaft. Operate the motor and switch it to the park function. With the linkage free from the motor, move the wipers by hand to the desired park position. Reconnect the motor to the linkage. I am gonna try this tomorrow. Hope it works.
1985 GTV2.5
post #3 of 6 (permalink) Old 05-20-2017, 05:03 PM
That is correct. But if the joints are sloppy it can difficult to park consistently.
gprocket is offline
post #4 of 6 (permalink) Old 05-21-2017, 06:34 AM Thread Starter
james2000's Avatar
Thanks gprocket.
I couldn't help but admire your garage contents. Do you still own all those gorgeous Alfas?
Cheers, James
1985 GTV2.5
post #5 of 6 (permalink) Old 05-21-2017, 07:58 PM
Alfajay's Avatar
It isn't accurate to say "Its only function is to pump wiper fluid" - the foot switch also runs the wipers at high speed for as long as the pedal is held down. If you just unplug the foot switch, the wipers won't work on low speed. So when your foot switch was eliminated, did you add a jumper to the foot switch connector to substitute for the normally closed connection in the switch?
Having said all that, I can't see how eliminating the foot switch would cause the parking problem you describe.
'63 Guilia spider
Alfajay is offline
post #6 of 6 (permalink) Old 05-22-2017, 07:45 AM Thread Starter
james2000's Avatar
You are absolutely correct. Before changing the wiper motor, we found only two strange wires connected to the foot switch and it became too complicated FOR US to correct the entire circuit. Since the car will not be used much in the rain, we decided to bypass the electrics the foot switch to simplify the restoring of the wiper function. We did not jumper the foot switch. Power is now connected directly to the wiper (console) switch. The wipers now work only from the wiper switch. The only use for the foot switch is the pump for the fluid.
Correct. The foot switch has no bearing on the park function. Sorry for the confusion.
Thanks for your comments, James
1985 GTV2.5
Replace with
